Autosports & Technique
General driving and racing...
confused in SCCA class for xb
Old Dec 22, 2005 | 03:40 AM
DeadRinger's Avatar
Default confused in SCCA class for xb
I have been poking around the SCCA website trying to find uut what class I would run my xb in. Currently I have just lowering springs on it, but I might throw on an intake, slightly better pads and brake fluid.... what class would I be running in? thanks in advance...
Old Dec 22, 2005 | 11:25 AM
Ashe_WCM's Avatar
DeepSouth Scions
Stock xB runs in HS
Stock allows you to change shocks , brakes pads/rotors, tires(not wheels) air filter(drop in only).
Sounds to me you will be running STS or FSP both of which are the next level that allows springs.
Old Dec 22, 2005 | 11:47 AM
DeadRinger's Avatar
oh yeah, I would have my 18" on also.... from what I have been reading in the forums I was thinking it would be STS, havent heard o the FSP though...
Old Dec 23, 2005 | 04:28 AM
dexter_5000's Avatar
don't put in a higher dot rating brake fluid you'll regret it if you do. mixing them will cause problems certain ones can be mixed not offten though. if you do it could turn the fluid to sludge and be useless all together.
Old Dec 23, 2005 | 12:59 PM
Tamago's Avatar
JUNK THOSE 18's!!!! worst autoX mod ever! you'll seriously be faster on your stock tires!
i run FSP but i have interior mods that put me there, IE non-airbag steeringwheel, gutted, and race seats.
glad to hear you'e gonna autoX it but for the love of god, get rid of those wheels! you can pick up a lightweight set of 15's for under 100 apiece, and race tires are as cheap as 25 bux used. you can run FSP on race rubber and clean house
Old Jan 5, 2006 | 05:23 AM
wooish's Avatar
I have springs and I was in the STS class this past summer.
Old Jan 6, 2006 | 02:06 PM
Tamago's Avatar
i'm hoping to be in SM very very sooon :D
Old Jan 11, 2006 | 05:23 PM
DeadRinger's Avatar
good advice, I will start looking for some 15's. I need to sign up for a refresher course here since it has been well over a year since I have done any racing. I would like to find a club to race with here also.... let me know what other tricks you have for your xb that helps you run better... thx
Old Jan 12, 2006 | 04:18 PM
Tamago's Avatar
check ebay right now.. do a search "enkei rpf1" .. there's a set of 15's WITH azenis already mounted.. great starter set of wheels.. can't beat 8lbs wheels
Old Jan 12, 2006 | 08:30 PM
DeadRinger's Avatar
shoot, cant grab them just yet, I decided to sell my 04 Expedition and I need to get rid of it first before I buy anymore "toys" (what my wife calls all mods).... But those would be perfect, I have started doing some searches and those are exactly what I want to get!! I will let you know how it all turns out, but thanks for the heads up !!
Old Jan 13, 2006 | 02:04 PM
Tamago's Avatar
if you buy them new, try and get closer to 30mm offset.. i'm running 23mm and i love it.
Old Jan 17, 2006 | 03:04 AM
Subcompact Culture's Avatar
Have autocrossed in the past, I understand the usefulness of a smaller wheel. However, I think a 15" wheel might be a bit small for autoxrossing an xB (maybe I'm wrong). It seems like with thexB's height, something a bit bigger might suit the car better. Then again, maybe a 205/50/15 would provide a big enough footprint for the xB to handle really well ...
Thoughts?
Old Jan 17, 2006 | 10:54 AM
Tamago's Avatar
a 205 hoosier will be way more than enough tire for the xB.
Old Jan 20, 2006 | 01:24 PM
So I might be picking up a set of 15s for daily use. Do you think a 205/50/15 or 205/55/15 would be a better tire for "spirited" driving? the 55-series tires is closer to the corrext diameter, but the sidewall is obviously taller.
Thoughts?
Old Jan 20, 2006 | 09:20 PM
Tamago's Avatar
i run 205 55 15's... i have no problems with them at all.. i ran 225 50 15 previously, and loved them even more.. a bit of front rubbing on a sharp turn (2.5" drop) but still not that bad..
please don't buy Falken Ziex 512's..
Old Jan 20, 2006 | 11:37 PM
I'm on my second set of Ziex 512s and I love 'em. I had them on my Prelude and now on my xB. I don't use them for autocross, just a daily-driver tire.
Old Feb 6, 2006 | 01:55 AM
JSosa's Avatar
i ran today with my xA and i did fakk in the HS category the prob is that with the suspension components that i have, if i add one more thing i get bumped up a class and thats not good!! But here are some pictures:
Old Feb 6, 2006 | 02:03 AM
what are you running for suspension mods?
Old Feb 8, 2006 | 02:08 PM
Tamago's Avatar
u race with NASA ?
Old Mar 20, 2006 | 09:57 PM
neuromonic's Avatar
JSosa, that's a beautiful course you are running on!
As for any auto-x tips, I only have one... I'm in a tc and I like to put my seat back, lock the seatbelt so it stays tight, and then move the seat forward. It's no four-point-harness, but it holds you in the seat reasonably well so you can concentrate on your stearing and pedal controls wihtout having to brace your knees against the door and center console. I don't know if it works on the box, but all the luck to you!
