Gold Rims
Originally Posted by aarontrini85
not realy gold more bronz but im waiting on these in the mail should be here next week
More info please!!! make/model/size/price. i like them in bronze.
Nathan
ycart1201
Nathan
ycart1201
make: BSA
Model: 325
Bolt Pattern: Universal 5x100 and 5x114.3
Offset: +40mm
Finish: Bronze
Weight: 17.5 lbs
im going to pick up some 10mm spacers to fix the 5mm diffrance from stock and then to move them out a bit more
and i know there heavy but hell there lighter then stock and i meen look at them
the tc is a +35mm off set and positive meens it is moving closer in on the car
so you want to add a 5mm spacer to a 40mm offset wheel to come out with a +35mm offset
i want to add a 10mm so i can have a +30mm offset but now that im looking at my car i dont know if that would cause issues with the stechs
and this is to the best of my understanding any one correct me please if im wrong
and the reason i dont buy stock offset wheels is becouse i got to good of a deal on these to pass up and i also coudnt find any thing in our offset i liked
You got it backward aaron. Stock tC has +45 offset. The wheels you are buying are +40 offset meaning they will stick out 5mm more. If you add 10mm spacer you they will stick out 15mm more than the stock which is equal to +30 offset.
https://www.scionlife.com/forums/viewtopic.php?t=98863
offset = the distance from the centerline of the rim to the inner surface where it attaches. So theroaticaly if you have 0 offset, the center of the rim lines up to where it attaches (stick out half the rim)
