Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Wheel & Tire
Register Forgot Password?
Fitments, widths, brands...
Click Here
View Poll Results: which offset would be better
19x8 45 4 40.00%
19x8 35 6 60.00%
Voters: 10. You may not vote on this poll
Reply
Old 12-29-2005, 05:11 AM   #1
rolstc
rolstc's Avatar
rolstc 27/M
Send a message via AIM to rolstc Send a message via MSN to rolstc
Default whats better offset 35 or 45 ?
im going to get 19" rims. Now im lost for offset. which one would be better for the Tc.
19x8 35
19x8 45
SE-CHICAGO
-event coordinator-
WWW.SE-CHICAGO.COM
(visit our website)
rolstc is offline   Reply With Quote
Old 12-29-2005, 05:27 PM   #2
Ninja4Hire
Ninja4Hire's Avatar
Ninja4Hire 37/M
Send a message via AIM to Ninja4Hire Send a message via Yahoo to Ninja4Hire
With the 45 ET on a 8 in wheel, your looking at 13mm less clearance on the inside with an extra 13mm sticking out.
With the 35 ET your going to get 3mm less then what you have stock with a fat 23mm more as far as sticking out goes.
So basically if you like your wheels more flush with the car, get the 35 ET. Plus the inner clearance is better if you end up getting a big brake kit.
I just got 18x7.5 35ET Konig Tuner II wheels but I have'nt put them on yet, cuz I want to install my springs first
You might wanna pack an extra sandwich, cuz I'm about to eat your lunch!!
www.StealthyGoat.com
Ninja4Hire is offline   Reply With Quote
Old 01-01-2006, 01:38 AM   #3
simplespirit
simplespirit
Send a message via AIM to simplespirit Send a message via Yahoo to simplespirit
An 8 inch wide wheel with +35 is going to rub. For an 8 inch wide wheel +45 to +48 is optimal.
simplespirit is offline   Reply With Quote
Old 01-01-2006, 03:08 AM   #4
taek
taek 24/M
Send a message via AIM to taek
35 is the better offset.
33 is flush
-taek
taek is offline   Reply With Quote
Old 01-01-2006, 12:15 PM   #5
simplespirit
simplespirit
What size tires are you looking at? If you stay with a 215 you might be ok with a +35 but any wider and you're going to rub on inside of the fender lip.
Try this post for all you ever wanted to know about offset: http://www.yoursciontc.com/forums/in...showtopic=8327
Old 01-02-2006, 05:36 PM   #6
raamaudio
raamaudio 61/M
Correction, you will be fine with 18x8 +35mm offset as long as your tires are not to wide. I run 17x8 +35 with 235/40/17s and do not rub.
I have done a few things to check some handling issues like run zero rear camber and had the car dropped almost all the way on the coilovers, only then would it rub over really big bumps in the rear and barely touched.
You will not have zero camber if dropped, some negative camber is dialed in from the factory at the stock height and you gain more when lowering the car.
17 vs 19 is not going to make much of a difference, again as long as you go with a reasonable tire width, 225 width may be a good plan to stick with.
If you want a wider wheen the you need to have a higher number +offset.
Rick
TT TC sold, back to street duty but with full race suspension, etc....
raamaudio is offline   Reply With Quote
Old 01-03-2006, 02:35 AM   #7
yamaha16bw
yamaha16bw's Avatar
yamaha16bw 29/M
Send a message via AIM to yamaha16bw Send a message via MSN to yamaha16bw
Will 10mm really much different when install on the car? Ive got this rim I really want 18x8 with a +45 offset. I dont really need it to be flush just better lookign the stock. Any input would great
yamaha16bw is offline   Reply With Quote
Old 01-03-2006, 03:08 AM   #8
The_Instigator
The_Instigator's Avatar
The_Instigator 32/M
Send a message via AIM to The_Instigator
18x8 +45 should fit just fine.
SOLD THE tC
Black 2006 WRX STi as of 7-9-06
The_Instigator is offline   Reply With Quote
Old 01-03-2006, 04:59 AM   #9
wayne33
wayne33 113/M
I have 18x8 with 35 offset. i have s-tech spring and no rubbing issues
wayne33 is offline   Reply With Quote
Old 01-03-2006, 05:59 AM   #10
jay_jay_n
jay_jay_n's Avatar
jay_jay_n 30/M
Send a message via AIM to jay_jay_n
anybody kno if 19x8.0 with +43mm offset rub on s-tech?
Sponsors:
NITTO, GLOWSHIFT, KILLER GLASS, CARSPONSORS.COM, INNOVA,http://www.JDMCARBOY.com,http://www.STICKERCITY.com
jay_jay_n is offline   Reply With Quote
Old 01-03-2006, 10:03 AM   #11
simplespirit
simplespirit
19x8 will probably be fine if you don't go wider than a 225 tire. If you do want wider, you're going to rub with that offset.
Old 01-03-2006, 10:06 AM   #12
simplespirit
simplespirit
Correction, you said +43 so you're probably ok up to a 235 or maybe even a 245 tire.
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
22, 35, 45, deeper, offset, tai, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
