Go Back   Scionlife.com » General » Maintenance & Car Care
Register Forgot Password?
Reply
Old 10-26-2003, 11:00 PM   #1
Flipper
Flipper
Default lug pattern ?
: is there any way to convert the 4x100 lug lug pattern to 5x114.3 so i can fit the rims i want onto my xb? Will it chnge the offset?
Flipper is offline   Reply With Quote
Old 10-27-2003, 11:04 PM   #2
DynamiteSJ
DynamiteSJ's Avatar
DynamiteSJ
Send a message via AIM to DynamiteSJ Send a message via Yahoo to DynamiteSJ
you can but it wont be cost effective at all... what i am thinkin is converting the front to corolla and the rear ... need to look around for that one.. but the offset will be changed
-= XOS PERFORMANCE =-
04 BLACK SAND SCION XB
DynamiteSJ is offline   Reply With Quote
Old 10-28-2003, 07:51 PM   #3
TheRedBox
TheRedBox
I was going to do that until I found out how much it would cost. I was doing it stricly for a very rare set of wheels i had found. But seeing how much I would have spent, you can get some 19 deep dish volks for that price..........
THE FIRST REDBOX.
I Miss my scion!
TheRedBox is offline   Reply With Quote
Old 11-04-2003, 10:20 PM   #4
Kendo
Kendo's Avatar
Kendo 40/M
Send a message via AIM to Kendo Send a message via MSN to Kendo Send a message via Yahoo to Kendo
Default or..
you can use a custom set of hubcentric spacers that have studs in a bolt pattern that will accomodate the wheels you want. This will of course depend on the offset of the wheels. What offset and bold pattern are these rare wheels?
Kendo is offline   Reply With Quote
Old 11-07-2003, 07:57 PM   #5
WeirdStyles_net
WeirdStyles_net's Avatar
WeirdStyles_net
Send a message via AIM to WeirdStyles_net
wheelspacers.com
Yea, some dont trust him for what ever rasons but why the hell not. Not only do you get your custom bolt pattern, but you also get a wider wheel base which is hunky dory with me...
Thank You,
Doc
http://www.clubscion.com
WeirdStyles_net is offline   Reply With Quote
Old 11-12-2003, 08:01 AM   #6
ScionVan
ScionVan's Avatar
ScionVan 36/M
Quote:
Originally Posted by WeirdStyles net
wheelspacers.com
Just clarifying, but you will actually be increasing wheel track width, not wheelbase. Wheelbase is the distance between the front wheels and rear wheels, as measured from the center of the wheel/axle. The downside to running wheel adapters to change your bolt pattern is you end up spending a couple hundred bucks for the adapters (assuming you get high quality ones, not cheapies that will put your life in danger if they fail prematurely), and you sometimes might end up spending more than if you had just gotten wheels with the standard Scion 4x100 bolt pattern in the first place.
Hi
ScionVan is offline   Reply With Quote
Old 11-12-2003, 02:39 PM   #7
WeirdStyles_net
WeirdStyles_net
van, however I am sure you're aware not all wheel come in 4-bolt pattren. Plus, not all wheel companies make blanks so you can have them drilled by a machine shop.
Someone had mentioned that the adapters put more strain on your bearings, but I dont see the connection.
ps. sorry you are correct about wheel base, i couldnt recall its proper nomdiclature so poped that out. I think people got the point. Thank you for the correction.
Thank You,
Doc
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
