Regional - Mid Atlantic DC, DE, MD, VA, WV
header/exhaust and MD emissions testing
Old Dec 30, 2005 | 02:46 AM
Chaos_Being's Avatar
Default header/exhaust and MD emissions testing
Ok, eventually I'd like to install a header and a cat-back exhaust with a hi-flow cat. It seems like in the past when I've had my other cars tested, all they do is check the gas cap and plug into the ecu and read the codes. I can't remember if they hook the exhaust up to a sniffer for new cars (I don't think they do); I'm pretty sure they don't do a visual inspection (for the presense/absence of cats.)
Basically I am wondering if could pass inspection with a header and exhaust combo, or if I'd get nailed. Having to switch back the stock parts for inspection would be a pain (but at least it would only be every couple of years.)
Also, I can't remember if the emissions testing is always every 2 years, or if the car needs to be inspected 5 years after its purchase (if new,) and then every 2 years after that. I've heard both, and it doesn't specify on the MVA's website.
Thanks!
Old Dec 30, 2005 | 04:37 AM
kanundrum's Avatar
my old benzo doesnt pass insp3ection all the time. i slip the guy a 20 and it passes cleaner then a hybrid. lmaoooo
Old Dec 30, 2005 | 12:45 PM
Haha, ok, does anyone know if I would pass inspection without bribing the inspector?
Old Dec 30, 2005 | 09:26 PM
black_xb's Avatar
you will pass emissions and inspection as long as you keep your o2's, and converter. But if doin this set up causes your check engine light to set a code you won't pass emissions.
Old Dec 31, 2005 | 05:57 AM
So basically no CEL = you pass eh? That's pretty much what I thought, just wanted to verify. Especially since I would be down one cat out of two with this sort of setup.
Old Jan 20, 2006 | 05:28 PM
cameracar's Avatar
They do a mirror check for a CAT. The mirror is fixed at the booth on the ground but I have seen the portables around if they want to double check.
Old Jan 20, 2006 | 08:15 PM
kzhorse's Avatar
Strictly Scionized
The truck I traided in on my box was a 1996 S-10 4.3 With true duals with 3 1/2" side pipes and no cats at all and it went thru no questions asked.
But it was easier when a friend worked there just gave him the money and notice and that evening he would bring the passed slip home to me.
Scott
Old Jan 22, 2006 | 10:29 PM
XD40tC's Avatar
I believe thats the only reason you passed... your experience will most likely NOT make this guy feel better.
Old Jan 23, 2006 | 07:54 PM
kzhorse's Avatar
Strictly Scionized
If your talking about me,My friend hasent worked there in 10 years.
If the OBD2 does not throw a code you pass.
Scott
SloTC1
Aug 16, 2018 02:45 PM
mudguy
Oct 22, 2015 04:31 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
hantaro
Sep 18, 2015 07:38 PM
ScionLife Editor
Sep 16, 2015 10:00 PM
