zpi crank pulley installation?
Old Jan 5, 2006 | 10:10 AM
bluenjsciontc's Avatar
Default zpi crank pulley installation?
ok well last night i took a crack at it i got everything off and whatnot , put the car in gear but the funny thing is ...when i went to remove it ...the motor still cranks with it ...so i dont know what im doing wrong...i called my friend nick up and he says i need to get a crank pulley puller to remove the crank pulley from the car ...is this true?
Old Jan 5, 2006 | 01:47 PM
nester's Avatar
put it in gear and it still moves? You have an automatic, don't you? Yeah, that won't work.
There are a few different types of pulley pullers.. If he's speaking of a puller that will hold the pulley and keep it from spinning, then yes.. that would help.
Old Jan 7, 2006 | 05:52 PM
no i have a 5 speed, no matter what gear i put it in it still rotates ....unless im missing something? like a way to lock the motor because all i do is rotate the block not the bolt ...
Old Jan 7, 2006 | 06:07 PM
jiujitsuking's Avatar
I had the same problem. Some people are saying that putting it in gear locks it and allows you to move it but that is not the case. I ended up taking it to a mechanic since you need impact tools. It cost me $80 but I know it's done right. You cannot do it with normal hand tools.
Old Jan 8, 2006 | 05:49 AM
Harmonic_tC's Avatar
yeas, you need to have an impact wrench to remove that bolt. there is no other way really unless you get a strap wrench and have a friend hold the pulley while you remove the bolt. The best way is an impact wrench, air or electric
Old Jan 8, 2006 | 10:48 AM
if i could find a place in NJ to do this for me, i would give them a call but theres no place thats like around the corner, and i dont feel like waiting 2 weeks for my air compressor
SuBSiN
Mar 13, 2015 04:02 AM
AxRxP
Jan 30, 2015 10:08 PM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
