Where to buy 410cc
Old Jan 6, 2006 | 01:02 AM
kirill's Avatar
Default Where to buy 410cc
Do You guys know where I can buy 410cc fuel injectors?
And what if I try them w/o e-manage?
Thank You!
Old Jan 6, 2006 | 01:50 PM
bbsciontc's Avatar
why 410's in particular? Thats not much larger than stock.
Old Jan 6, 2006 | 01:54 PM
Simplyscion's Avatar
Team No Limitz
thats what i was gonna ask
Old Jan 6, 2006 | 01:57 PM
Team No Limitz
Default Re: Where to buy 410cc
Thank You!
putting them on without any management isnt gonna do anything for ya but maybe run a slight bit richer at idle because of the different spray pattern/pintle design. Why dont you try something like a 550cc injector while running less duty cycle...this keeps the injector from maxing out and helps prevent lockup of the injector.
Old Jan 6, 2006 | 02:45 PM
kirill's Avatar
becouse TRD uses them
Old Jan 6, 2006 | 02:50 PM
Team No Limitz
More of a reason not to use them
But seriously, TRD uses them cause they gotta try to keep everything as close to OEM specs as possible...with 550's in they probably wouldnt pass CARB
Old Jan 6, 2006 | 04:35 PM
kirill's Avatar
So, I run 6-7 psi w/o any additional fuel.
If I get 550cc and no e-manage am I going to run reach enough
for 8-10 psi?
Thank You.
Old Jan 6, 2006 | 04:57 PM
Team No Limitz
for 8-10 psi?
Thank You.
nope...u need management, as I said before...adding injectors without telling them what to do doenst help you.
Old Jan 6, 2006 | 05:09 PM
nester's Avatar
You can run the 410's from the TRD kit on the stock ecu, like most said.. they're not going to do much for you.
The stock injectors have enough flow for about 6-7psi on our 16g, depending on the flow of turbo/sc, your a/f may vary...
We can sell you RC injectors in any size you want, we generally have 550's in stock.
Old Jan 7, 2006 | 03:07 AM
kirill's Avatar
Thank You guys!
Old Jan 7, 2006 | 12:29 PM
zer0's Avatar
Kirill have you decided on an engine management yet?
Also where you at in MD? I wanna see your car....
Old Jan 8, 2006 | 03:24 AM
kirill's Avatar
yes, I have. Waiting for zpi quote..they are good ...
I'm in Baltimore county, Where are You?
jctc06
Apr 16, 2015 12:11 AM
thefranks5
Mar 25, 2015 08:24 PM
webekyle
Feb 7, 2015 07:15 AM
nstripoffreporter
Jan 23, 2015 06:29 PM
Ramroids55
Jan 16, 2015 02:42 PM
