ZPI Supercharger Pulley
Old Jan 6, 2006 | 06:36 AM
bunnyfart's Avatar
Default ZPI Supercharger Pulley
I read a post on the ZPI Supercharger Pulley and had a question, because there was no concrete answer on it... is the pulley bad for the engine, since it is a solid piece as opposed to have the vibration absorbing materials integrated (like the stock pulley)? i like the fact that it will give ~20+ whp, but i dont want a broken engine in the long run... has anyone had any issues running the pulley? thanks in advance.
Old Jan 6, 2006 | 07:28 AM
datrickster24's Avatar
Your not going to get a solid answer really. The pulley just came out and people have only had them for maybe weeks tops now. But it IS going to affect your engine in the long run since it is not from factory, changing the pulleys youll be putting more power but also more stress to the supercharger. But with just a pulley i dont think you have much to worry about.
-Dan
Old Jan 6, 2006 | 07:50 AM
kungpaosamuraiii's Avatar
The supercharger pulley shouldn't cause any trouble like that.
It's the crank pulley that is shrouded in controversy but that's because it's connected to the crank aka the source of all the vibrations and thus the source of dying 2JZ engines that were running solid pulleys.
The supercharger woulnd't be the source of any of that kind of trouble as it's not the piece that's turning other accessories.
Old Jan 6, 2006 | 12:45 PM
zoltiz's Avatar
N.G.S.O.
OEM SC pulley is just as solid as the ZPI pulley. The only thing you are changing in this case is boost, so all the problems will be from higher boost, not solid pulley...
Old Jan 6, 2006 | 01:11 PM
Munch's Avatar
Exactly
Old Jan 6, 2006 | 01:15 PM
JT_Scion's Avatar
I've had the ZPI pulley for about 2 months now.. No problems, no squeeks, vibrations, noises, just boost
Old Jan 6, 2006 | 07:22 PM
ryno379's Avatar
That's good to hear since I just ordered mine 2 nights ago.
Old Jan 6, 2006 | 10:01 PM
motozen's Avatar
dito.
Old Jan 6, 2006 | 11:22 PM
TheQuietThings's Avatar
well... ading more boost will mean adding more heat, which will lead to faster break down on the engine.
but as long as you arent beating on the engine and redlining at every stop light, then you should be fine. It shouldnt significantly shorten the life of the engine, or any of the engine components. If anything, just make sure your fuel system is working properly. WIth 9-10lbs of boost, you are running close to your limit on the supercharger injectors.
Old Jan 7, 2006 | 12:06 AM
Nick06tC's Avatar
Sorry to thread jack, but is there a thread that discusses the results of the increased boost on the fuel curve?
I want to put the pulley on next week, but I want to make sure it is safe.
Old Jan 12, 2006 | 03:49 AM
ryno379's Avatar
I had my ZPI supercharger pulley installed yesterday. There is a very noticeable difference in performance. I am very impressed. There is no difference, however, in driveability or idle or anything negative. There may be a slightly louder whine from the s/c, or it could just be in my head. I ordered late Wednesday night, and the pulley arrived Monday morning. I am completely satisfied with this upgrade.
Old Jan 12, 2006 | 03:36 PM
Nu_ERA's Avatar
ScionERA
The whine is a little louder to me as well. I just had the Boost pulley and the New Crank pulley installed. OH MAN! I love it!
Old Jan 12, 2006 | 05:39 PM
DTRUONG_112's Avatar
which crank pulley did you get? Dyno?
Old Jan 12, 2006 | 06:33 PM
nester's Avatar
Yep, more whine because the supercharger is spinning faster.. Thanks for the glowing review!
Old Jan 12, 2006 | 07:10 PM
blastedat9's Avatar
Team XcelsiA
is there a ZPI pulley that ups the boost to over 9 psi? i was hoping to go more into the 11-12 range. i know the NST pulley is out, has anyone dynoed that?
Old Jan 12, 2006 | 07:38 PM
hPower's Avatar
The NST pulley puts the boost level at 9.5 to 10psi. Get the NST SC pulley and then wait for their crank pulley to come out as well. Then you will be in the 12psi range
Old Jan 12, 2006 | 08:18 PM
that would be nice.
Old Jan 12, 2006 | 08:24 PM
zer0's Avatar
Is 12psi safe unintercooled? It gets decently hot here in the summer, dont want to be driving around boosting and BOOM.
Old Jan 12, 2006 | 09:32 PM
BreakTheStatic's Avatar
At 12psi I would definitely be running an intercooler, especially if you'll be running it in a hot climate.
Old Jan 12, 2006 | 11:25 PM
Simplyscion's Avatar
Team No Limitz
your gonna need unichip/emanage over 10 psi...the car is gonna run way tooo lean anything over that
