Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 02-02-2006, 09:35 PM   #1
t_urbo_C_harged
t_urbo_C_harged's Avatar
t_urbo_C_harged 26/M
Send a message via AIM to t_urbo_C_harged
Default THE FI Comparison Thread - Turbo and S/C Packages
The thread made for everyone (noob or not) that encompasses both turbo and s/c kits, the accessories of each kit, the price, the website, and pics of them. The FI Kits...
TRD Supercharger
TRD USA Website
Sparks Toyota Website
Price: $2950
Output: 180-190hp & 200-210tq @7psi
Components:
- TRD Supercharger
- TRD 400cc Fuel Injectors
- Idle Pully
- TRD lower air-box
- Air Filter
- Bosch Bypass Valve
- TRD fuel supply line
- TRD Denzo spark plugs
- TRD modified heat shield
- Oil Pan with return tube
- Reflash Program (requires reflash ECU adapter; reprograms ECU)
- Upper Radiator hose
- Other misc. accessories (brackets, shims, etc.)
- TRD Badges
Dezod
Dezod Motorsports Website
Price: $3975
Output: 244hp & 255tq @8.7psi
Components:
- Turbonetics Dezod Spec'd T3/T4 turbo
- Stainless Steel manifold (log style)
- Tial 38mm Wastegate
- Charge Piping with Intake
- Dezod Turbo install kit
- Stainless steel downpipe including S-pipe
- HKS BOV
- Fuel System with 550cc injectors
- Stainless Steel braided oil lines & oil pan fittings
- Large Bar and plate front mount intercooler (FMI)
- Clamps and Couplers
- Pretuned GReddy E-manage with Plug N' Play
Zero Point Industries
ZPI Website
Stage 0
Price: $2670
Output: 230whp & 250-260tq @ 6psi
Components:
- Big EVO III 16g Turbo
- Tial Wastegate
- Tial BOV
- Stainless charge piping
- 4 ply couplers
- Stainless manifold
- All fuel and timing tuning already complete
- Pre-tapped Oil Pan
- Satin or black chrome piping
- Misc hardware and instructions
Stage 1
Price: (from ZPI website) $4500; $3999 (RacingSolution.com)
Output: 290-300whp & 300-330tq @9-10.5psi
Components:
- EVO III GT Big 16g (max performance = 400hp)
- Tial Wastegate (color of choice)
- Tial BOV (color of choice)
- Stainless Intercooler piping
- Precision Turbo intercooler with cast end tanks
- Pre tapped oil pan
- Pre tuned Emanage
- 550cc RC injectors
- Stainless Manifold (log style)
- 4 ply couplers
- All Hoses & Accessories
Turbonetics
Turbonetics Website
Price: $4200 (what I found of a thread, $5,975 in the parts section I believe)
Output: 300hp @ 8psi (at crank with 94octane fuel)
Components:
- T3/T4 E-50 Ball Bearing Turbo
- Spearco Intercooler
- Rapter Blow Off Valve
- Evolution Wastegate
- Unichip engine management
- Stainless oil feed line
- TS-1 fully synthetic engine oil
- Taps for oil return and oil feed fittings
- Stainless downpipe with wastegate dump tube
- Cast ductile exhaust manifold (log style)
- Black chrome mendrel bent aluminum intercooler pipes
- Silicone hoses
- K & N filter
- 4 drop-in 630cc Motron high flow injectors
- T-bolt and V-band clamps
- Nuts, Bolts, and fittings
Sound Performance
Sound Performance Website
Price: Scion life = $4500 Retail = $4999
Output: 260hp & 280tq @ 7psi
Components:
- SP TC 32 Turbo (non ball bearing)
- Tubular Stainless Steel Turbo Header
- Delphi 440cc Injectors with clips
- SP TC Front mount intercooler with pipes (bolt on no cutting the bumper)
- SP TC Complete return fuel system
- Fuel system includes
- All high pressure line
- All a/n fittings needed
- Aeromotive fuel pressure regulator
- Liquid filled pressure gauge
- Fuel Rail with return fitting welded on
- Tial 38mm waste gate with a 7lb spring
- Turbo XS blow off valve
- Apex Safc II (black or silver)
- Ceramic Coated - Manifold/down pipe/turbo (hot side)
- Powder Coated - Intercooler pipes and Air Intake Pipe(any color)
- Polished-Turbo (compressor housing)
- Oil Pan with fitting welded in
- Oil Return line with fittings
- Oil Supply line with fittings
- Stock fuel pressure regulator welded closed
- All couplers and clamps
- AEM 3in Dry flow filter
- NGK Spark Plugs
Greddy
Greddy
Price: $2700 (shipped)
Output: +100hp & unknown tq (probably about the same)
Components:
- Mitsubishi/GReddy TD-05H 18G turbo
- Stainless steel tubular manifold
- Cat-delete down pipe (2-piece)
- Intercooler included (Type-31V)
- Aluminum intercooler piping
- Airinx Air Intake
- All clamps & necessary components
If there are any mistakes or you want to add some information on a kit just say the word! Stephen
t_urbo_C_harged is offline   Reply With Quote
Old 02-03-2006, 12:37 AM   #2
paul_dezod
Sponsor
Scionetics
paul_dezod's Avatar
paul_dezod 13/M
Send a message via AIM to paul_dezod
We include a TiAL BOV (color of choice with matching WG)
Our downpipe includes the S-Pipe too
www.dezod.com
P: 716-681-6666
E: paul@dezod.com
FEEDBACK FOR DEZOD
paul_dezod is offline   Reply With Quote
Old 02-03-2006, 12:42 AM   #3
t_urbo_C_harged
Ahh, sorry about that, I will fix it! Very nice kit by the way! also does your kit come with fuel injectors? I know it said fuel system, just didn't know what that consists of... Stephen
Old 02-03-2006, 12:55 AM   #4
paul_dezod
Sponsor
Scionetics
paul_dezod's Avatar
paul_dezod 13/M
Our kit comes with 550cc injectors
Thanks!
www.dezod.com
P: 716-681-6666
E: paul@dezod.com
FEEDBACK FOR DEZOD
Old 02-03-2006, 01:32 AM   #5
t_urbo_C_harged
Thanks!
Awesome , added it to the list!
Old 02-03-2006, 01:41 AM   #6
BigPinoyTC
BigPinoyTC's Avatar
BigPinoyTC 113/M
I know that my car is turboed by SP so you all might think im all for them but i thought i would just say the one difference that stands out to me with the comparisons with these kits is that ZPI, Dezod used pre tuned Emanage units and Turbonetics uses a chip and SP was able to do all this with a SAFC. Not saying one is better than the other, just wanted to point that out.
eAsYdOeSiT
Sponsers:
Sound Performance
Dunlop Tires
Axis Wheels
AEM
BigPinoyTC is offline   Reply With Quote
Old 02-03-2006, 01:51 AM   #7
BigPinoyTC
BigPinoyTC's Avatar
BigPinoyTC 113/M
oh yeah ....... also it would be nice if all companies can meet and battle out against each others kit. We can make an entire event out of it.
Just a suggestion. I'll bring my car.
eAsYdOeSiT
Sponsers:
Sound Performance
Dunlop Tires
Axis Wheels
AEM
Old 02-03-2006, 01:57 AM   #8
datrickster24
datrickster24 25/M
Send a message via AIM to datrickster24
Nice comparison post, along with noobies, helps us lazy ppl! I dont get how meeting will help find out which kit is better. They are all tuned differently with different specs. Just my .02!
-Dan
datrickster24 is offline   Reply With Quote
Old 02-03-2006, 01:58 AM   #9
unlimited77
unlimited77 27/M
I think, like clubrsx.com there should be a sticky on the topic "which turbo kit fits me" or something like that...lol
unlimited77 is offline   Reply With Quote
Old 02-03-2006, 01:59 AM   #10
t_urbo_C_harged
Quote:
do you have any dyno numbers on your kit... yes I noticed the same exact thing, not saying the pre-tuned e-manages are bad and I'm not saying that the Unichip is bad (although you can only get it programmed at a unichip shop, which sucks if you want/need to tune) its just nice that all can be done on a SAFC!
Old 02-03-2006, 02:01 AM   #11
BigPinoyTC
BigPinoyTC's Avatar
BigPinoyTC 113/M
Quote:
-Dan
The meet wouldnt be for comparison ... just for the hell of it!!! Its a good excuse for all of us to meet and do nothing but drink, drive fast cars...and if there are some good lookin honies....well you know!!!!!!
eAsYdOeSiT
Sponsers:
Sound Performance
Dunlop Tires
Axis Wheels
AEM
Old 02-03-2006, 02:03 AM   #12
BigPinoyTC
BigPinoyTC's Avatar
BigPinoyTC 113/M
My car was the SP test car. The first and only car so far with their kit. The numbers they posted are from my car 260 whp and 280 wtq. Soon to be more hopefully.
eAsYdOeSiT
Sponsers:
Sound Performance
Dunlop Tires
Axis Wheels
AEM
Old 02-03-2006, 02:05 AM   #13
t_urbo_C_harged
this would be great! it would be also better if they battled it out as far as prices and tested stock vs. stock with just what comes with the kits, and see who has the best E.T.'s at the track and horsepower numbers on the dyno, and whoever has the best gives away a few kits???
very true that each kit is tuned different, thats why it should be like a contest to see who has tuned theirs the best
Old 02-03-2006, 02:10 AM   #14
t_urbo_C_harged
-Dan
Thanks, I thought it would be very convienent so that's why I did it also... I was considering scionspeed but from everything going around about the company and a guys motor blowing, it just wasn't up to my par
Old 02-03-2006, 02:11 AM   #15
BigPinoyTC
BigPinoyTC's Avatar
BigPinoyTC 113/M
YEAH FREE KIT......I WANT ONE!!!!!!!!
OH NVM I DO HAVE ONE!!!!!!!
eAsYdOeSiT
Sponsers:
Sound Performance
Dunlop Tires
Axis Wheels
AEM
Old 02-03-2006, 02:13 AM   #16
t_urbo_C_harged
you need to get a dyno video up ASAP! Must be nice to have the only kit out and have your car be the tester...
Old 02-03-2006, 02:22 AM   #17
Scottydo
Scottydo 30/M
Send a message via AIM to Scottydo
well, if we are going to drive, we should probably not do the drinking
Scottydo is offline   Reply With Quote
Old 02-03-2006, 02:31 AM   #18
BigPinoyTC
BigPinoyTC's Avatar
BigPinoyTC 113/M
We can drink!!!!
It'll be a controlled environment. Those who are drunk have to stay the night until they sober up in the morning. We will have a big a$$ camp out!
eAsYdOeSiT
Sponsers:
Sound Performance
Dunlop Tires
Axis Wheels
AEM
Old 02-03-2006, 03:02 AM   #19
rlazer5000
rlazer5000 28/M
Send a message via AIM to rlazer5000
We can drink!!!!
Hell yeah I'm down with that!
rlazer5000 is offline   Reply With Quote
Old 02-03-2006, 08:36 AM   #20
beezyyy
beezyyy 113/M
Send a message via AIM to beezyyy
hey guys, well im plannin on gettin turbo for my tc in prolly 4 months or less, well im a noob to this stuff, but def. interested.
first, im prolly not gonna install the turbo my self, so how much wuld it run me for me to get it installed at a quality shop.
Any of these turbos are easier to maintain and such for a beginner liek me and wat kind of stuff do i do to maintain the turbo
one last thing is that my friends have been telling me that turbo is too overwhelming on the tc engine or sometin like tht, is there any truth to this. thnx !
beezyyy is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
280, bolts, fi, fl, fuel, industries, manifold, oil, orlando, point, presure, rail, regulator, return, scion, tc, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
