Rear Wiper noise
Old Feb 26, 2006 | 03:27 PM
codycat's Avatar
Default Rear Wiper noise
Rear wiper rubs against glass and creates constant sqeek noise, when blade goes down. Tried cleaning windows, but will have to be looked into during next dealer service. Vehicle has only 3,500 miles.
Old Feb 26, 2006 | 03:30 PM
mattross's Avatar
mine has 31,000 and does it as well.
Old Feb 26, 2006 | 03:32 PM
codycat's Avatar
sounds almost like it's scraping the glass.
Old Feb 26, 2006 | 11:27 PM
ProshopXB's Avatar
Did you change blades or try rainx?
Old Feb 26, 2006 | 11:35 PM
cjastacio's Avatar
I don't think there is anything you can do about it. Since the wiper only has one speed it dries the window rather quickly. When the window is dried you get the same effect of a squegee running along dry glass. I think that is the squeeking noise you get.
Old Feb 27, 2006 | 12:11 AM
Pitman's Avatar
Just remove it and plug it....mine never worked well........cjastacio has a good point about the drying.
look at this post https://www.scionlife.com/forums/vie...709&highlight=
gives you some ideas.
Old Feb 27, 2006 | 12:30 AM
Cmec2004's Avatar
yea mine does it do sometimes but i think i need a new blade
Old Feb 28, 2006 | 04:53 AM
mattross's Avatar
it doesn't do it the whole window. just when it reaches the bottom inc or so and it sounds like scraping no a squeege
Old Feb 28, 2006 | 09:30 PM
codycat's Avatar
mattross~That is correct. You must be having the same problem..
Old Feb 28, 2006 | 09:32 PM
evilBOXevil's Avatar
Here's how I fixed mine...
Old Mar 4, 2006 | 10:23 PM
jeanann's Avatar
Default Wiper noise
If noise is caused by wiper blade chattering against the glass as it moves, try wiping blade several times with a soft cloth loaded with rubbing alcohol..this solved my problem.
Old Mar 5, 2006 | 06:12 PM
This mod works the best...When it rains, doraemon jumps up and wipes my window for me. It's so quiet I barely know he's there.
Old Mar 5, 2006 | 06:28 PM
THE_DON's Avatar
Time to do some shaving
I never found a hole plug that looked good enough.
The rear wiper makes too much noise! I just use rainX and have no problems.
-THE DON
Old Mar 5, 2006 | 06:36 PM
The DON is right on. It stays clearer with the rainx and no wiper, than with the wiper by itself. ..and no squezky noises.
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
George
Nov 18, 2003 09:34 AM
