hello... I was wondering if there was a way to reset the factory radio... I hooked up a wire harness to have an amp hooked up to my stock radio... Well my problem is that after I was done I was listening to my radio and after a few minutes out of nowhere it just shut off...so I uninstalled the wiring harness and hooked it back the way it was and it still does not want to work.. it wont even turn on...what the hell happened??? thx all
BYOB... System Of a Down, yeah baby...
Did you cut any wiring when you connected the wire harness???
Moved.
__________________ Ned ===Retired SL Super Mod=== Pinoy 4 Life
'08 2AZ-FE MT | '08 2AZ-FE AT | '07 Lexus JZS190 what moves you | the relentless pursuit of perfection
Yea I know, I have the same one in my car it works great. I even leave it connected when I take my subwoofer out. The only thing I can think is that you let the signal wire for the amp turn on touch a ground and it blew a fuse for the radio. Which one is it? Look in your manual.
there's a fuse box right above your kick panel under the dash on the driver's side. the cover just pops out and there is a label that shows which fuse corresponds to. you can also check inside the engine bay, there another fuse box in there with labels. good luck.
I looked all over and none of those fuses are for the radio and I called the dealership and they said they have to pull out the radio to get to the fuse??? does anyone know anything about that????
