tC and rims
Old May 27, 2004 | 04:51 AM
theheckwithyou's Avatar
Default tC and rims
okay since some of u guys have the owners manual
and i'm not really in to rims but i don't know how this works so
what are the stock rim size
i'm planning to buy OZ superturismo 18x8 5x112 offset 35 will they look right?
Old May 27, 2004 | 04:55 AM
djimpak's Avatar
stock rim size is 17x7, 5x100 and 45 offset.
courtesy of cypher50
Old May 27, 2004 | 05:07 AM
hmmm so. will it fit? like i said eailer i have no clue on rims
Old May 27, 2004 | 05:11 AM
DuMa's Avatar
http://www.tirerack.com/upgrade_gara...5&autoModClar=
Old May 27, 2004 | 05:21 AM
djimpak's Avatar
18x8 with 35 offset will probably fit but not the 5x112 part.
Old May 31, 2004 | 05:34 AM
RyaN21's Avatar
anyone know how much stock wheels weigh?
Old Jun 3, 2004 | 02:43 AM
integsrtite's Avatar
i've been reading up about tires and rims and i just wanna know if i'm on the right track so please correct me if i'm wrong:
1) tire size "215/45ZR17" 215mm is the width of the tire, .45 is the ratio of tire height to tire width, 17" is the inner radios of the tire, otherwise used for the rim size
2)size "17x7JJ" 17 is again the rim size, 7 is the rim width
3) PCD is the diameter of the circle formed by the bolts
4) offset is the distance between the center line of the rims and the inner edge of the bolts, + being outwards and - being inwards (relative to the car)
assuming that i have been correct so far, i have 2 questions:
1) the tire itself is 4cm wider than the rim... is this normal?
2) if the offset determines whether the the tire will be too far outwards and rub against the frame of the car... given a correct offset, are there any measurements to determine if a rim/tire combination would rub against the area directly above the tire? this should have something to do with the suspension as well right?
thanks guys!
Old Jun 3, 2004 | 07:14 AM
tinybigrig's Avatar
you should be able to fit 19x9 no problem in the back....heheh i head someone test fir a 19x 10 already too.....hmmmm i think 19x8.5 is the biggest you can run in the front of the car...and by the way bolt pattern is 5x100
brent
Old Jun 3, 2004 | 10:08 AM
iZero's Avatar
thanks guys!
The thing you need to keep in mind is a tire is round (when you look at its cross section) and flexes a lot during use. Not only that, the wheel it's mounted on can vary is width. As such, you can' use conventional measurements.
Old Jun 3, 2004 | 12:15 PM
Milhamscion's Avatar
where can I get a set of Dunyearstones for my ride? they look awesome!!
Old Jun 3, 2004 | 10:14 PM
djimpak's Avatar
hahaha ditto! i want some.
Old Jun 3, 2004 | 11:26 PM
Onyx's Avatar
I have seen the TRD 19s on a flint mica model here at work, and they are sharp! The 19s really give the car a different look. It looks like a $35k-$40k sports car with 19s.
Old Jun 4, 2004 | 12:05 AM
hbmike11's Avatar
ONYX please post pics
Old Jun 12, 2004 | 09:15 AM
S_on_Da_5's Avatar
Good info. What about bore size?
Old Jun 12, 2004 | 12:59 PM
hal9000's Avatar
Onyx is right about the 19's..car looks like 3 series or A4...links to front and rear shot of Flint Mica w/19's and springs. I'll probably get this setup then throw Blizzaks on the 17's for winter.
http://f2.pg.photos.yahoo.com/ph/bus...c9.jpg&.src=ph
http://f2.pg.photos.yahoo.com/ph/bus...c7.jpg&.src=ph
Old Jun 14, 2004 | 06:57 AM
SERG4U's Avatar
Just so everyone knows here is the price of the 19" rims with out the TRD http://store.finalstageauto.net/19rhproj5wh3.html
Old Jun 14, 2004 | 11:54 AM
erc's Avatar
erc
I was really hoping to pick up some 18" RH Pro J5's in gunmetal with the polished lip, but it doesn't look like they exist in anything other than a 19" wheel. Is that right?
Old Jun 14, 2004 | 04:59 PM
djimpak's Avatar
^^^ only 19". sucks because i also wanted those in 18".
Old Jun 14, 2004 | 05:42 PM
erc's Avatar
erc
Bummer. I really like the wheels, but I personally think the 19's look a little too big.
That, and I don't think I would enjoy shelling out $1000 every time I need new tires.
Old Jun 14, 2004 | 05:49 PM
djimpak's Avatar
i'll be getting these instead of the J5s
