View Poll Results: OCTANE... WHAT DO YOU USE TO FILL YOUR xB??
87
84.47%
89
7.77%
91-93
7.77%
Voters: 103. You may not vote on this poll
Old May 28, 2004 | 02:45 PM
MIKE_DEGUZMAN's Avatar
Default OCTANE... WHAT DO YOU USE TO FILL YOUR xB??
https://www.scionlife.com/forums/vie...light=kind+gas
i know its been talked about over n over ^^^^ but never really polled.....
Old May 28, 2004 | 02:50 PM
Magnus's Avatar
'87 octane in all my stuff, even the air cooled biked. None of it says it requires higher octane and I will not get a performance or mileage boost using it so why waste my $$$ on gas (that is high enogh already) when I could be spending that green on my machine.
Old May 28, 2004 | 02:53 PM
kwicslvr's Avatar
Ditto! Only time you should run it is on high compression cars, nitrous, or forced induction.
Old May 28, 2004 | 03:21 PM
cmdxb's Avatar
isnt 87 what the manual says?
i know my q45 says use PREMIUM ...ON THE GAS DOOR!!!...lol WTF?
BlueScionXB's Avatar
Rockin 87 all the way...
Old May 28, 2004 | 03:24 PM
Reno's Avatar
ditto. why spend $ to get nothing in return..........
Old May 28, 2004 | 03:53 PM
ditto here, freaking gas was at 2.25 for 87 where I am at. maybe once a month I hit up a chevron and fill it with 91. Thats only on a good day in a month!
Old May 28, 2004 | 05:07 PM
ScionMikey04's Avatar
I also use only 87 octane preferably from Chevron because it has Techron in it which is good for the fuel injector's.Gas price's here are between 1.91 to 1.95 for regular unleaded.
04 Xb RS 1.0 #0686 of #2100
17-inch Black Motegi Racing RT-5's with Toyo Proxes All-Season 215/40ZR-17
AEM CAI
PrecisionMuffler.com axel-back
The Box is pretty much loaded out.
ScionMikey04 Let's just all try and get along and live in peace.
Old May 28, 2004 | 06:17 PM
TheScionicMan's Avatar
Running higher octane in a car that can't utilize it also contributes to air pollution and smog...
Old May 28, 2004 | 06:29 PM
cliffy1's Avatar
You ain't kiddin' about the Techron. Did you know its essentially the same stuff as Yamaha REQUIRES you to add to all their outboard engines to prevent carbon build-up on the rings?
Old May 28, 2004 | 06:47 PM
IAxB's Avatar
don't have mine yet but I'll be burning 89 ethenol blend, cause in Iowa its state subsidized(sp?) so its normally 2-3 cents cheaper than 87 plus since it has corn alchohol in it it helps the Iowa economy, and it burns cleaner. been using it in every vehical I've owned from my 79 320i to our current 04 Matrix and always seen better milage and fewer fuel related problems.
Old May 28, 2004 | 09:54 PM
im usin 93 octane. i really dont know why to tell you the honest truth. i guess im just used to it. my bmw n xterra ran better w/ 93. or... maybe it was just my imagination... who knows... but i use 93.
Old May 28, 2004 | 09:59 PM
JDMxB's Avatar
Old May 29, 2004 | 07:52 PM
satanisanerd734's Avatar
well since gass in South fl is $2.10 i gots to use 87.. but if it ever drops back down.. mayb i can afford 93.
Old May 30, 2004 | 10:02 AM
nosSER's Avatar
Default wow
you guys lucky 87 where i'm at is $2.25 but i have been putting 91 @ $2.55 I dont know why I guess i'm used to it too having an n20 car.
Old May 30, 2004 | 03:31 PM
DeanCouchey's Avatar
87 for us, costs 2.13 a gallon at the cheapest spot. Exxon and Mobile are at about 2.20 or so
Old Jun 28, 2004 | 01:09 PM
claffeyb's Avatar
In the old days, you could use higher octane to compensate for pinging, but not with the computer-controlled systems these days. Higher octane gas is slower burning, and since your car's computer does not know what octane you put in it, it leaves more deposits if you use higher octane, More deposits means that eventually you will have an engine with higher compression, which means that then you have to use the higher octane gas to keep it from pinging. Does not make sense to fall for marketing hype of the oil companies. But, I do concur that Chevron with Techron is the gas to use because it helps control deposits. Alternately, use the Techron additive to keep the deposits down or use BG-44K once a year.
Whie I'm on this subject, many don't realize that fuel additives that claim to reduce deposits on valves and injectors do their job when the engine is turned off. The fuel with the additive sits on the deposits and softens them, which allows them to be "blown off"/disolved when the engine is started up again. It does not make sense to add the additive and then drive 300 miles on that tank. You won't be getting any benefit.
Lastly, if you get the additive in a combination with claims to remove water from fuel, that basically is done with isopropyl alcohol. If you want to remove water that gets in your tank due to condensation (yes, it happens all the time), get a bottle of the water remover that has ispropyl alchohol, not methanol alchohol. Don't get a diluted deposit remover product with it added, as it won't do either job as well as either individually.
Old Jun 28, 2004 | 01:55 PM
Craig_X1's Avatar
Originally Posted by IAxB
Burning 89 Ethanol blend, cause in Iowa its state subsidized(sp?) so its normally 2-3 cents cheaper than 87 plus since it has corn alchohol in it it helps the Iowa economy, and it burns cleaner.
Ditto
Old Jun 28, 2004 | 03:22 PM
dinkjs's Avatar
I use 89 octane....but for long trips like when I go to see my father in Ohio I use 93 for better gas mileage
Old Jun 29, 2004 | 05:15 AM
NHGrafx's Avatar
I just use plain regular unleaded. It costs anywhere from 1.50 to 1.90 a gallon here depending on where you go.
