Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Drivetrain & Power
Register Forgot Password?
Reply
Old 04-15-2006, 06:38 PM   #1
scionlife
Founder
Admin Emeritus
scionlife's Avatar
scionlife 37/M
Default Buyers Guide: Scion xA/xB Exhaust
TRD Exhaust System
Type: Axle-Back
Part Number: 00602-17400-150
Colors: Polished
Application: Scion xB
CARB EO Status: Approved 2004-2006 xB
MSRP: $299
Street: $299
Manufacturer's Site: www.trdusa.com
Relevant Threads:
http://www.scionlife.com/forums/viewtopic.php?t=111965
http://www.scionlife.com/forums/viewtopic.php?t=59143
http://www.scionlife.com/forums/viewtopic.php?t=46137
This is the exhaust that is most likely to be found in your Scion dealer's parts department. TRD is a subsidiary of Toyota, so fit and finish of their products are almost always up to OEM standards -- this exhaust is no exception. More of a cosmetic upgrade than a true performance improvement, but then again it is still an improvement. Exhaust tone is slightly louder, but not obnoxious. Idle note is deeper than stock, freeway drone is not too bad and full-throttle has a note of far more urgency.
Pricing is a little steep because it is sold through Scion dealerships, but you can occasionally find one online for around $250.00. Installation is straightforward and only takes a couple of minutes. Includes new gasket and all necessary hardware.
Pros: OEM Dealer option so can be financed with new vehicle, Toyota techs won't give you weird looks
Cons: OEM Dealer option pricing, everyone has one, not that much performance gain
Rating: Click the image to open in full size.
scionlife is offline   Reply With Quote
Old 04-15-2006, 06:42 PM   #2
scionlife
Founder
Admin Emeritus
scionlife's Avatar
scionlife 37/M
OK guys, I got the ball rolling on this one... lets get all the information up here so that noobs can make easier decisions!!
Old 04-16-2006, 01:00 AM   #3
surfcity40
surfcity40 86/M
ty
surfcity40 is offline   Reply With Quote
Old 04-18-2006, 02:28 PM   #4
coalhalo
coalhalo 43/M
Thanks for the info. I'm definately a Scion noob and I'm trying to figure out some good exhaust and intake options.
coalhalo is offline   Reply With Quote
Old 05-10-2006, 09:51 PM   #5
Jhhnn
Jhhnn 64/M
Just installed the TRD axleback on my xB, apparently I needed a refresher course in why I hate exhaust work....
Coupla tips. Don't try to pull the nut off of the pipe clamp- it's welded on. Pull the bolt instead. Spray some water into the rubber hangers before trying to remove the muffler- a little lube goes a long way. Soapy water would probably work even better.
It fits perfectly, with the tip naturally centered in the opening, and it's really not very loud, at all. I'm actually kinda disappointed... I've read that they get a little louder with age, so we'll find out...
I went with the TRD unit to avoid warranty issues, and because I didn't want it to be *too* loud or ricey looking. It's neither...
Jhhnn is offline   Reply With Quote
Old 05-11-2006, 04:53 AM   #6
XBoxDooDah
XBoxDooDah's Avatar
XBoxDooDah 64/M
Great, I'm getting ready for that move myself. Have done the YDR ram Air.
XBoxDooDah is offline   Reply With Quote
Old 05-17-2006, 07:22 PM   #7
GooseNaBoxxx
GooseNaBoxxx's Avatar
GooseNaBoxxx 30/M
I went with a Borla axleback. Not sure of the gains, it feels a little better. Its alot deeper than the stock exhaust, but not too loud. Of course, I kind of wanted louder so you knew I had a different exhaust, but if I rev it, those who own a stock xB can tell. I would recommend it, easy to install, came with a sticker (i did not put it on my box), and comes with instructions! Got it on eBay...give it a try.
-Goose in a Boxxx
:quack:
GooseNaBoxxx is offline   Reply With Quote
Old 05-17-2006, 08:04 PM   #8
BUCKO
BUCKO 32/M
Default TRD cat-back exhaust
I used to work for Borla Perf and they, at least back in 2000, made the TRD system. Given that that is still true i'd compare the price of those two kits. IMO i'd go with something cheaper as long as its a 'flow-through' design. The stock Scion exhaust is mandrel bent anyway so my guess is if your gunna keep the cats on (CA state legal at least) just replace the rear muffler. Save some flo $$$ if you dont have it to spend.
-- SMD
From Land Rover to Scion... 'what does that say?'
BUCKO is offline   Reply With Quote
Old 05-17-2006, 08:18 PM   #9
BUCKO
BUCKO 32/M
More TRD/ Borla info. It is true that the exhaust system will 'break-in' after time because the packing in the muffler will condense and not absorb as much sound (thus passing it through). As for worring about exhaust voiding your warranty, SEMA has lawyers that make sure there are laws in place to protect aftermarket parts manufacutres. To the best of my knowledge, law states that the aftermarket part would have to mechanically or in some logical way cause failure to a stock component. example. It is not logical that an exhaust system would cause your engine to 'throw' a piston or rod. In that sense they could not say that the vehicle (in whole) is out of warranty. Now if your muffler melts the rear fender then it could be justified that it was an out of warranty occurance. I'd suggest that you go to SEMA.org and educate yourself, it could help you as well the next time you get pulled over, it's not illegal to have aftermarket performance parts on your vehicle. most companies a registered though SEMA anyway so doing business with them is a good ideal.
-- SMD
Old 06-04-2006, 02:21 AM   #10
dmbrown79
dmbrown79's Avatar
dmbrown79 33/F
Send a message via MSN to dmbrown79
What is the stock inlet pipe diameter? Is it 2.50, 2.25. or 2.00?? I've seen them all. What's stock??
http://www.cardomain.com/ride/2293251
http://www.myspace.com/mistybrown
2006 Scion Release Series 3.0 Envy Green
Tejas Toyota - Humble, Texas
My New Pick3 Numbers= #525 of 2200
Nickname: Pandora's Box
dmbrown79 is offline   Reply With Quote
Old 06-20-2006, 02:58 AM   #11
Neebski
Neebski's Avatar
Neebski 25/M
Send a message via AIM to Neebski Send a message via MSN to Neebski Send a message via Yahoo to Neebski
Alright, this might be sad... So I just got my xb and I need some more power, I feel like im driving my go kart around town whats your best suggestion for a exaust? Im not to worried about the price anything works. Thanks!
Neebski is offline   Reply With Quote
Old 06-25-2006, 01:42 AM   #12
jpauletteUSAF
jpauletteUSAF 28/M
Send a message via AIM to jpauletteUSAF
Uh, no axleback exhaust for the xB is going to give you ANY noticeable power gains. The best axlebacks for the money are the Precision Muffler axleback and the Strup exhaust, IMO.
jpauletteUSAF is offline   Reply With Quote
Old 06-29-2006, 03:26 AM   #13
HotBox420
HotBox420's Avatar
HotBox420 27/M
not much here to be calling it a buyers guide.
06 Turbocharged
HotBox420 is offline   Reply With Quote
Old 06-29-2006, 04:41 AM   #14
Big_Bird
Moderator
Big_Bird's Avatar
Big_Bird 24/M
Send a message via AIM to Big_Bird Send a message via Yahoo to Big_Bird
DC Sports single canister axleback, will be getting the cat-bakc as soon as it comes out
well not a large power gain, but def more pep, and much louder than stocker, especially after i put in my Injen sri. Good quality, very easy to install and remove, i take it out, clean it and reinstall every couple months. Def worth the mpney for what you get.
My Flickr
OMG Pancakes
OMG Pancakes on FBook!!!!
My Toaster Thread
Learn how to Search
Big Hindu and the Banana Wagon
NJ/NY BS'er Foh Lyfe l Team Crayola : Mahogany l EOS SQUAD
Big_Bird is offline   Reply With Quote
Old 07-04-2006, 12:01 AM   #15
k_dub
k_dub's Avatar
k_dub 113/M
Send a message via ICQ to k_dub Send a message via Yahoo to k_dub
Hey wat about N.V.?
Get at me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
k dub dim dizzel
k_dub is offline   Reply With Quote
Old 07-06-2006, 05:14 PM   #16
ScionJazzy
ScionJazzy 30/F
Send a message via AIM to ScionJazzy Send a message via Yahoo to ScionJazzy
I have a DC Sports Axle-back exhaust too...I went to a muffler shop and got 2" piping installed as well....it's pretty sweet! Sounds good and you can feel a little more power.
Injen CAI, Ceramic Coated Headers, DC Sports Exhaust, Espillar Lowering Springs.... This is only the beginning......muahahaha
ScionJazzy is offline   Reply With Quote
Old 07-08-2006, 06:30 PM   #17
zdawg913
zdawg913's Avatar
zdawg913 25/M
Send a message via AIM to zdawg913
im getting the TRD for my xA... and i am also getting a high-flow cat with resonator (magnaflow universal) to go with it. how much louder will that make the TRD exhaust? i have also ordered the Injen CAI.... all input welcome. thanks!
zdawg913 is offline   Reply With Quote
Old 07-09-2006, 10:54 PM   #18
CobraStngSVT
CobraStngSVT's Avatar
CobraStngSVT 31/M
Send a message via AIM to CobraStngSVT
Default ...
I think i have narrowed my options down to the greddy or the borla cat backs. Anyone have any experience with the greddy yet?
2006 Scion xb - The Daily/Part-timeToy
1995 Mustang Cobra - Full-time Toy
CobraStngSVT is offline   Reply With Quote
Old 07-18-2006, 04:35 AM   #19
Kiss
Kiss's Avatar
Kiss 32/M
im getting the Greddy SP2. its only an axle-back though.
Scikotics Western Regional MFIC
www.SCIKOTICS.com
Proudly sponsored by STRUP Performance
R.I.P. EVLTSTR
Kiss is offline   Reply With Quote
Old 07-21-2006, 12:37 AM   #20
Doctorsub
Doctorsub 31/M
Default Exhaust Me?
How are the Tanabe exhausts? Any word how well it matches with the Injen xb short intake?
The doctor
Doctorsub is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2006, dealerships, espillar, exhaust, exhust, ks, leak, loud, scion, system, whats, white, wichita, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
