Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 04-20-2006, 01:49 PM   #1
SuperWTC
SuperWTC's Avatar
SuperWTC 31/M
Send a message via AIM to SuperWTC
Default Supercharged 1320ft results. 4/28
The motor is offically broke. 3 cyls have no compression. I installed the s/c and they said it dosent matter. They will warranty it!!!!!!!!!!
I ran my s/c'd tc last night and didnt do so well. I expected a little more. Car has the 9lb pulley, bosh 110, megan header, zpi crank pulley, and 18" wheels. The best mph was 93, and the best time was 14.94. The best 60ft is 2.18. Does this seem right? I honestly expected a little more mph and lower et. Im doing some research now on water injection and possibly a 10-11 lb pulley. Opinions and comments are welcome.... Scott
www.eastcoastpwc.net
SuperWTC is offline   Reply With Quote
Old 04-20-2006, 01:52 PM   #2
Simplyscion
Simplyscion's Avatar
Simplyscion 30/M
with those mods you shoulda had a top speed of about 96- 97 mph...what points were you shifting at? Your 60 ft time isnt terrible cause of wheel spin, but makes me think you might have bogged a lil off the line?
04' Blue Onyx pearl xB ~Turbo~6psi *sold*-blown up by new owner lol as of 3/06
05' Yamaha R6 Raven edition~black rocket~
06' Nautical Blue S/C tC~totalled 9/24~
06' Premium White Pearl Acura TSX-drive slow homey
www.smithtownscion.com 631-724-3300
Holla at your boy Vito for any new or used Scion
Smithtown Scion #1 volume dealership in the tri state
Simplyscion is offline   Reply With Quote
Old 04-20-2006, 01:56 PM   #3
SuperWTC
SuperWTC's Avatar
SuperWTC 31/M
Quote:
shifting 6000-6100. All three runs were almost identical. Also a friend tried it out and pulled the same numbers.
Old 04-20-2006, 02:01 PM   #4
Simplyscion
Simplyscion 30/M
do you consider yourself a fast ____er? Do you put the clutch all the way to the floor when you shift? Did your tires break loose in 2nd gear? I see so many people instantly shift the car when their tires are spinning in 2nd once it comes close to the redline, but in reality you gotta hold it there for a second cause eventually the wheels will bite and drop back in RPM's and then you got another few hundred RPM's to pull.
Old 04-20-2006, 04:39 PM   #5
kcautotc
kcautotc's Avatar
kcautotc 28/M
no, those times are dissapointing, i agree.
simplyscion is simply correct. if you want those faster trap times, you have to master that first and second gear. from what ive heard, and what simply scion is saying to. call out to desertheat, who ran a 14.3, maybe you could get some tips? the tc really is a good "drag" car because of the shorter gears, but it bites you in the ___ when the tires just want to spin all day. also, what rubbers are you using? i didnt see anything in your list. if you can spend around 800 bucks for tires, ill be willing to bet that you can get down to around desertheats times. the times you were doing sound like stock sc times, maybe you have belt slip on the pully?? i would say dyno your car, and if your not around 210, 215 then somethings obviously wrong. my 2 cents, but dont give up hope.
kcautotc is offline   Reply With Quote
Old 04-20-2006, 04:57 PM   #6
hPower
hPower 33/M
Yeah man, those numbers do sound more like stock numbers. What tires are you on? Stock suspension?
If I were you I would go back and try it again. Drag racing is all about the launch and the shifting. I bet if you keep practicing and experimenting a few different methods on the track you can probably knock off at least a couple of tenths.
Here is one tip for you., try lowering your tire pressure if you are running cheaper all season, or an average tire brand.
hPower is offline   Reply With Quote
Old 04-20-2006, 06:12 PM   #7
SuperWTC
SuperWTC's Avatar
SuperWTC 31/M
Im on trd springs, and have dunlops 901r's i think. As far as shifting. That could be an issue but from what i remember, the shift were fast and smooth. Next step is dyno and see from there.
Old 04-20-2006, 06:45 PM   #8
Simplyscion
Simplyscion 30/M
are you using the stock belt on the pulley?? Do you have a boost gauge?
Old 04-20-2006, 06:57 PM   #9
SuperWTC
SuperWTC's Avatar
SuperWTC 31/M
Im running a smaller belt and no boost guage.
Old 04-21-2006, 03:53 AM   #10
kcautotc
kcautotc's Avatar
kcautotc 28/M
it sounds like you know what your doing on your shifting, i suspect its in your launch, and your prob not at full power.
Old 04-21-2006, 02:11 PM   #11
Simplyscion
Simplyscion 30/M
it could still be the belt slipping a lil bit...we will never know until he hooks up a boost gauge. Also, it is a kind of light 60' time with F/I...did you start off clean off the tree or did you bog
Old 04-21-2006, 02:21 PM   #12
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
Send a message via AIM to DouBLeJ16
What was the 1/8th mile ET and trap speed?
And a 2.1 60' is not bad at all with 18s.. Another member on this forum ran a 14.3 with the SC and the same exact 60' time.
I don't think this is a launch problem at all.
- K&N CAI, Megan Header & S-pipe, Megan Drift Spec Exhaust, AP Crank Pulley -
9.82 @ 73.44
^^ Traded in for '04 350z (8.87 @ 81.3mph bone stock down to the air filter & tires)
DouBLeJ16 is offline   Reply With Quote
Old 04-21-2006, 02:26 PM   #13
Simplyscion
Simplyscion 30/M
**** I forgot he had 18's on the car
dam bro, look under your hood and see if you got black dust all under the pulley and on your ABS module around the area near the pulley.
Old 04-21-2006, 02:41 PM   #14
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
I'm starting to wonder if we'll ever see a SC'ed tC in the 13s.
9.82 @ 73.44
Old 04-21-2006, 02:49 PM   #15
Stu_Gotti
Stu_Gotti 30/M
I dont think so.. maybe a few..
Stu_Gotti is offline   Reply With Quote
Old 04-21-2006, 02:57 PM   #16
Simplyscion
Simplyscion 30/M
Quote:
huu?? Ive got the same mods as desertheat and then some(management and tranny work)...If I had time to get down to the track I think it would be safe to say I would hit high 13's
Old 04-21-2006, 03:11 PM   #17
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
Currently the best is 14.3.. If you can do better then go ahead..
I hear alot of SC'ed tC owner's say that their car is good for 13s, yet no one has a time slip better then a 14.3.. And that was on his best run, he said he was averaging 14.5-14.6
9.82 @ 73.44
Old 04-21-2006, 03:17 PM   #18
Simplyscion
Simplyscion 30/M
I think I might just do that...thanks for the permission Dad
dont bother responding back either...all your posts are taken with a grain of salt as you seem to come on this site and think you know everything there is about cars
Old 04-21-2006, 03:20 PM   #19
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
lol, just don't be late for dinner.
Seriously though, I'm just calling it like it is.
9.82 @ 73.44
Old 04-21-2006, 07:10 PM   #20
mikescion
Happy Birthday!
mikescion 28/M
Default Re: Superchargerd 1320Ft results
damn not tring to flame you but i had the SAME times but the thing is mine is a N/A check my mods no F/I there buddy.... sorr only thing i can say is try again.
1st N/A to do 14.90 @ 92mph
1st customer's car to go 12.79@ 106mph <--stock motor
All times done on 225/45/17 BFG's drag radials
mikescion is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
