Tien SS
Old Jun 4, 2004 | 06:40 PM
xboxPS2's Avatar
Default Tien SS
are these the ones that are remote controlled so u can adjust from the drivers seat?
i'd rather have these than spending like 3 grand for bags installed.....
Holler at me
Jeff
Old Jun 4, 2004 | 06:50 PM
JDMxB's Avatar
Some Tein SS systems feature a Tein upper mount that is compatible with the EDFC--which is the Electronic Dampening Force Controller.
This doesn't not raise/lower the car from inside--this only adjusts the dampening.
Also, the Tein SS system for the xB does not feature Tein upper mounts, you must reuse your stock ones.
So no EDFC for the xB when using the Tein SS.
Old Jun 4, 2004 | 06:54 PM
DJ_SpaRky's Avatar
Check this out:
octopus3699
Old Jun 4, 2004 | 06:58 PM
xboxPS2's Avatar
good thing that link didn't work but i did a search and it had NO MATCHES at all sry
Jeff
Old Jun 4, 2004 | 07:00 PM
JDMxB's Avatar
That Tein xB in FL had CUSTOM made upper mounts in order to use the EDFC.
If you want to talk about all the things you could do with unlimited money and not out of the box functionality, we could shoehorn a Big block V8 into an xB.
Without doing major custom work (as in getting custom upper mounts made by Tein) you will not be able to use the EDFC on any of the Tein Coilovers currently out for the Scions.
Old Jun 4, 2004 | 07:05 PM
xboxPS2's Avatar
i've never seen the xb with the edfc, i've seen them on celicas and such and was just wondering thanks for the info....any ideahow much those custom upper mounts cost that guy have a pic?
Jeff
Kik
May 10, 2015 12:36 AM
eddiewinslo5
Jan 29, 2006 05:06 PM
WeeMan
Dec 27, 2005 10:24 PM
ProjectD
Jun 23, 2005 01:49 PM
The_Zeeness
12
Jun 1, 2005 11:43 PM
