loose aftermarket shift knob
Old Apr 28, 2006 | 01:11 PM
bbsciontc's Avatar
Default loose aftermarket shift ****
So I bought one of those aftermarket shift ***** from ebay awhile back. It uses 3 retarded set screws that routinely come loose. I am thinking of options to actually have the **** thread over the shifter. Has anyone done something like this? Bringing it to a machine shop crossed my mind, but that would be way too much for a **** that costs only 25 bucks. Only reason I'm even entertaining this thought is because I like how it goes with the car (real silver CF ball). Any suggestions are greatly appreciated.
Old Apr 28, 2006 | 01:48 PM
markritch's Avatar
maybe its the wrong thread size
Old Apr 28, 2006 | 08:26 PM
bbsciontc's Avatar
well the thing is the **** is one of the universal pos that isn't internally threaded. It comed with a plastic sleeve that fits over the threaded portion of the shifter, then the **** slides over this and is held in place with three set screws which I have to retighten everyday. I suppose what I'm looking for is a way that I could actually thread the **** onto the shifter like the oem one. It's alot harder than it sounds since the threaded shaft is smaller than the hole in the shift ****, so tapping it is out of the question.
Old Apr 28, 2006 | 08:32 PM
j10's Avatar
j10
try using plummers tape on the threads of the 3 small screws... it should hold it in place... i have the same type of shift **** but mine has not loosened yet...
Old Apr 28, 2006 | 11:18 PM
nfiniti9's Avatar
you can try using loctite one the set screws but you will not get it back off if you use the red i think. the blue will allow you to remove it (with alot of force) later.
Old Apr 29, 2006 | 01:58 AM
bbsciontc's Avatar
thanks for the feedback. I think i'lll try some of these. I noticed that they have self locking set screws on www.mcmaster.com , that use nylon inserts. If it doesn't work out too well then I may order some of these with the right thread.
NonStopTuning
Jun 29, 2015 07:42 PM
sciontcguy15912
Apr 7, 2015 06:32 PM
disaster06
Feb 3, 2015 08:50 PM
Scionxa180
Scion xA Aero & Exterior
Jan 8, 2015 08:33 PM
pro710
Dec 29, 2014 06:52 PM
