225/45/17 with a 42 MM offset?
Old Nov 10, 2003 | 02:10 AM
OOHC's Avatar
Default 225/45/17 with a 42 MM offset?
Anyone have any comments. I plan on ordering the wheels before thce car gets here so I just wanna make sure I won't have any rubbing issues.
Oh the wheels are 7in wide.
Old Nov 10, 2003 | 02:17 AM
squirrel's Avatar
i'm not sure how much of the sidewall will be bulging, but I'm running 205/40-17s on a 7 inch wide wheel w/42 offset, and I barely have 1/4" clearance in the rear.
I think Randode is running 215s, and he barely has 1/8".
squirrel
Old Nov 10, 2003 | 02:21 AM
OOHC's Avatar
Crap. I might end up doing a 215/50 which is the route I don't want to do.
Old Nov 10, 2003 | 04:32 AM
Hardhitten's Avatar
That doesnt sound right. I ordered 215/35/18 42 offset for 18's and People on this site said that should fit with no problem.
Old Nov 10, 2003 | 12:27 PM
OOHC's Avatar
I know the 225 on a 7in wide won't be a problem because we have it on one of our sponsored cars. I just wanna make sure they won't rub and if they do what needs to be modified to fix that problem. The real issue is that we have a large East Coast show in May so we need to have at least 90% of the parts in for the Xb before we even get the thing. (Arriving in Febuary)
Old Nov 10, 2003 | 04:36 PM
scionara's Avatar
I had 225x40x18s on 18x7.5 wheels with 42mm offset lowered 2" with spy springs and the front rubbed on full turn and also on those nasty freeway/road dips/bumps. I ended up changing the fronts into 215/35/18s. No more rubbing in the front.
Old Nov 10, 2003 | 05:03 PM
OOHC's Avatar
Thanks I think I'm just gonna do a 215/45/17 since I'm within the 3% diameter change. Thanks for the help.
Old Nov 18, 2003 | 07:42 AM
scionce's Avatar
Hmm, I was thinking about doing 2xx-40-18 on my setup, how much are you lowered? Do you know if the speedo gets thrown off if I go with the 40?
Old Nov 18, 2003 | 12:25 PM
OOHC's Avatar
Ordered car not here yet. I'm on the east coast. Reason I was asking is because we have to get the car ready in 1 month upon recieving it since we are using it as our 2004 show car. We plan on lowering it with eibahcs. I know th saturn performance site has a tire calculator that will give you speed readings for different tire sizes.
Old Nov 18, 2003 | 03:41 PM
randode's Avatar
Wagonistas
it should be ok. if it does rub on the rear, the part that rubs can be ground down, or you can run like a 5mm spacer.
xBrelease08
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
