Go Back   Scionlife.com » Scion xA » Scion xA Owners Lounge
Register Forgot Password?
2004-2006.5 [NCP61]
Reply
Old 05-03-2006, 11:48 PM   #1
jdanticoli
jdanticoli 51/M
Default CHARCOAL CANISTER
I have a new 06' Xa w/ 1500 miles. The check engine codes that were run show a fuel vapor charcoal canister malfunction. Any ideas regarding the cause? I read somewhere in SL that it is caused by water infiltration. Am I going to have this trouble everytime I use an automatic carwash? Where is the canister located anyway? please advise.
vty,
jo d a
jdanticoli is offline   Reply With Quote
Old 05-03-2006, 11:51 PM   #2
NOLA_Xa
NOLA_Xa 25/M
i think i have the same problem. i have an 04 with 21k on it. the canister is on ur gas tank, it is for emision. from what i hear and read, Toyota will fix it, but it goes out again. Aparently its a pretty common thing on the xA's. i dont think it being cracked will hurt the car, but i could be wrong, and u should still bring it to a dealership.
NOLA_Xa is offline   Reply With Quote
Old 05-03-2006, 11:53 PM   #3
ricktoyota73
ricktoyota73 40/M
Send a message via Yahoo to ricktoyota73
Right rear of the car near the fuel tank. It's black and about shoebox size with some valves and hoses going to it. one hose goes to the fuel tank.
I doubt water is getting in from the outside, unless it's cracked or there is a leaky hose or something. It could be from moisture in the fuel system though.
We have seen the vaccuum switching valve on various models cause a check engine light...yours appears to be part of the canister. I guess the valve will stick sometimes causing the light.
Parts Pro at Toyota/Scion Of Grand Rapids
Let me know if you need anything
toyotaofgrandrapidsparts.com
ricktoyota73 is offline   Reply With Quote
Old 05-04-2006, 12:00 AM   #4
jdanticoli
jdanticoli 51/M
Thanks Nola, I have an appointment to have dealer replace the unit tomorrow. I want the check engine light reset for any future malfunctions. I heard that it alerts you if the cam is messed-up. I hate these "dummy-lights"; I would much rather have gauges,i.e. oil pressure, engine temp, voltage, etc.
vty,
jo d a
Old 05-04-2006, 12:03 AM   #5
jdanticoli
jdanticoli 51/M
Thx. RickT. for the enlightening reply. I will ask the service tech. what he finds and report back.
vty,
jo d a
Old 05-04-2006, 02:34 AM   #6
TheCor
TheCor's Avatar
TheCor 30/M
i had the same problem and it was replaced under warranty. i know there was another post on here for a while about the spark plugs being gapped wrong on the cars and that could have been a problem why this part of the emissions was going bad all the time, but thats another discussion, just a thought. i had mine replaced at close to 5k i think? and i just upgraded to denso irridium plugs
point is, the dealership should fix it, and you're not the only one with the problem, lots of people have reported it, so i wouldnt worry too much
-2010 SW xB-
TheCor is offline   Reply With Quote
Old 05-04-2006, 03:46 PM   #7
willmw
willmw's Avatar
willmw 50/M
Is this the problem that can occur when you "pack" your gas tank? Seems like I was told that you stop pumping when the pump clicks off....or something will go wrong with the charcoal fuel canister. Maybe I'm thinking about something else.....
willmw is offline   Reply With Quote
Old 05-07-2006, 02:47 PM   #8
jdanticoli
jdanticoli 51/M
thanks everyone, had the canister replaced no charge[under warranty] on Thursday 5/4/06. repair tech wasn't sure but thinks the "pump"{?} or did he mean valve{?} inside the unit went bad.
Also, a Service Bulletin from Toyota Central has been issued to Scion repair shops for this item.
p.s. these guys were not a day over 20years old and never been to "Toyota University". I thought these service techs are supposed to be specialized, highly trained dudes...what's up?
vty,
jo d a
Old 05-07-2006, 03:27 PM   #9
dexter_5000
dexter_5000's Avatar
dexter_5000 32/M
Send a message via AIM to dexter_5000
some of them get sent by the dealer to a faster way of training which is all the stuff you can learn in 2 years in like a couple of weeks. its more stuff all at once. when they send them that way. not the best way to learn everything
dexter_5000 is offline   Reply With Quote
Old 05-07-2006, 03:54 PM   #10
scionzfiction
scionzfiction 36/M
There is noboby on this site that knows more about this than myself. I have had the canister replaced (3) times sinces purchasing this vehicle in early January '06. Yes high pressure car washes will effect the canister ( as will heavy rainfall w/ flooding). High Pressure water frome the car wash got into the canister, then staying there and freezing (during the winter) causing it to crack and thus triggering the CEL. Sunrise Toyota (Long Island) has since learned to install a shield over the canister to prevent from happening again, unfortunately this learing curve had to happen on my time. Overall (4) round trips to the dealer for the same problem. The first time this happened, I had less than 500 miles on the car, I was really ____ed off to say the least. The light was coming on almost on weekly basis after the initial faulter. My suggestions to these so-called Toyota techs, is to contact Sunrise Toyota, NY and learn how to properly shield these canisters, otherwise Scion should have a recall and just do this for all Xa's past and present.
form follows disfunction
scionzfiction is offline   Reply With Quote
Old 05-07-2006, 04:03 PM   #11
dexter_5000
dexter_5000 32/M
did you call scion and report the findings?
Old 05-08-2006, 10:57 PM   #12
jdanticoli
jdanticoli 51/M
CHECK THIS OUT...After getting the faulty canister replaced, my gas mileage increased dramatically! How could this be since the device is supposedly just a gas vapor filter?
vty,
jo d a
Old 01-26-2008, 10:21 PM   #13
anorthosite
anorthosite 114/M
Default charcoal canister malfunction
I WAS NOT SO LUCKY:
My light came on less than a month ago. I checked the gas cap and re-set the fuse and it went out, but then came on again after a week.
I took my 06 XA in (by appointment) today. The good news was that it took less than 2 hours. The bad news was that because my car has 42K it was NOT covered under warranty !! If the stupid thing had failed just 5 months ago, I would be $580 less poor. So, my loss may well be a result of the southeastern drought
They replaced the canister($314) canister filter no 2 and and the fuel tank filler pipe cover. They said it would NOT happen again. I sincerely hope not, as I really like this car and don't want to wind up Googling "lemon law".
anorthosite is offline   Reply With Quote
Old 02-15-2008, 05:09 PM   #14
mark_bernasek
mark_bernasek 49/M
Default charcoal canister--my turn
This problem has just happened to me. I purchased my '06 xA in July '06 and my CEL light came on about a month ago and after ordering (then reordering) the parts, it has finally been repaired (Feb. 200. I was told that it was under warranty (which it was) and that once the four parts were replaced, that I should notice an increase in my gas mileage. Too early to tell on the gas mileage. This was the second severe Nebraska winter that the auto has weathered (is garaged outdoors) so am curious if freeze/thaw might be a factor. Prior to this problem, I was questioning the 38-40 mpg that the model boasted but my driving is mostly in the city. Has Toyota/Scion diagnosed the most likely root of this problem (poor design, weather, particular driving habits, etc.). Am interested in any feedback so I might know what might lie down the road (so to speak). Thanks.
mark_bernasek is offline   Reply With Quote
Old 02-17-2008, 12:37 PM   #15
badbasic
badbasic's Avatar
badbasic 49/M
the feds have handled that. there is new testing procedures now for fuel mileage that started this past year. look @ an 06 model of any car and then compare it to an 08 model(same engine of course) and you will see that the mileage estimates have gone down to more "life like" estimates.
185,000 mile club
Sponsored by: former USOC(unemployed scion owners club)
badbasic is offline   Reply With Quote
Old 02-18-2008, 07:26 AM   #16
bB2NER
Music City Scions
bB2NER's Avatar
bB2NER 110/M
Send a message via Yahoo to bB2NER
Default Re: charcoal canister malfunction
Quote:
Originally Posted by anorthosite
I WAS NOT SO LUCKY:
I could be wrong but, I think the charcoal canister is covered under the 100K mile emissions warranty along with the cat. Either way if there is known issues with these things the dealer should have taken care of it for you free of charge.
Jeff
05' BCP xB W/ 48K miles
08' Absolute Red Yaris LB 5spd. W/ 42K miles
bB2NER is offline   Reply With Quote
Old 01-19-2009, 09:13 PM   #17
LeroyJMC
LeroyJMC 34/M
Send a message via AIM to LeroyJMC Send a message via MSN to LeroyJMC Send a message via Yahoo to LeroyJMC
Digging up an old thread.....
I got the CEL a couple weeks ago and received the parts for the TSB over the weekend. The canister and charcoal filter are simple enough to swap out, but does anyone know the proper way to replace the fuel tank filler pipe cover holder and the fuel tank filler pipe cover? I've been unable to find any guides for the replacement on these two little pieces.
Thanks.
2006 Flint Mica XA
35% tint
18 x 7.5 Konig Unknown
215/35/18 Toyo FZ4
Eclipse AVN6600 with TV Tuner
DC Sports Carbon Steel Strut Bar
Progress Rear Sway
MMW 4-2-1 Header
AEM CAI with Bypass
RS-R Exmag GTII Exhaust
LeroyJMC is offline   Reply With Quote
Old 01-19-2009, 10:46 PM   #18
jct
jct's Avatar
jct 74/M
i've had the dealer warranty work the gas filler tube few years back
yeah no help from me there heh
i'm sure its not that hard to do
i replaced my airbags with confetti
i need 50 more posts before i can post in the classifieds section!!!
ಠ_ರೃ
jct is offline   Reply With Quote
Old 01-19-2009, 11:13 PM   #19
LeroyJMC
LeroyJMC 34/M
I'm lucky enough to be SOL on warranty. I'm under 3 yrs, but have 64k already.
Yeah, I'm betting that it's not more than a 15-20 minute thing to replace the filler tube pieces, but figured I'd be smart not to muck with it until I hear from someone where I will not cost myself more money. $300 is enough already...especially when I've got a new Rubicon Unlimited that I could be spending money on goodies for.
2006 Flint Mica XA
35% tint
215/35/18 Toyo FZ4
Progress Rear Sway
MMW 4-2-1 Header
AEM CAI with Bypass
Old 01-19-2009, 11:27 PM   #20
jct
jct's Avatar
jct 74/M
i got a service manual on cd, if you wanna pm me your email addy i can send the part your gonna be working on to ya
ಠ_ರೃ
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2005, 2006, cam, canister, charcoal, crack, filler, fuel, oil, scion, send, tc, tube, unit, vapor, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
