Go Back   Scionlife.com » General » Maintenance & Car Care
Register Forgot Password?
Reply
Old 11-11-2003, 05:22 PM   #1
McG_XB
McG_XB's Avatar
McG_XB 113/M
Default Concern about alloy wheel cleaner
I've been using that alloy wheel cleaner in a spray bottle that that takes the grunt work out of cleaning the wheels. I think that most of these wheel cleaners are an acid base and my concern is whether or not this stuff will cause premature deterioration of the brake lines and/or CV boots, or any other rubber stuff that the cleaner may come in contact with.
NOR*CAL Scion
McG_XB is offline   Reply With Quote
Old 11-15-2003, 08:21 AM   #2
kagero79
kagero79's Avatar
kagero79 113/M
Send a message via Yahoo to kagero79
Well, most of CV & brake lines are pretty tough to withstand beatings, so I wouldn't worry too much about damaging your rubber or plastic materials, as long as you hose them down with lots of water as soon as you spray those products. I use Meguiar's all wheel cleaner, it says it's safe for all kinds of wheels and you're supposed to hose it down 15 seconds after you spray their product. I'd be more careful with rims rubbing on any hoses in the wells though. Try using like Simple Green, they're great on stains & grease for serious cleaning and their also environment friendly.(so they say)
kagero79 is offline   Reply With Quote
Old 11-15-2003, 02:09 PM   #3
rjsalvi
rjsalvi's Avatar
rjsalvi
I'll concur with Kagero79 -- Simple Green works well as a cleaner and I've not found it to be damaging to any metal. I use it mainly to keep the painted areas in the fenderwells clean, but I suspect it would as well be a good choice for wheels. Since I use it on painted surfaces, I would also venture to guess that it's safe to use on painted/clear-coated wheels. As always, YMMV.
rjsalvi is offline   Reply With Quote
Old 11-15-2003, 03:42 PM   #4
scionracerxb
scionracerxb's Avatar
scionracerxb 113/M
i like to use the "orange clean" degreaser...just a couple shots of that and the dirt will run off. I used to use that new castrol purple degreaser on my last set of rims, but it was too powerful and ate the clearcoat off in about 6 months!...never worried bout the cv boots or rubber tho
DO WATCHA GOTTA DO
scionracerxb is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
alloy, cleaner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
