Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Wheel & Tire
Register Forgot Password?
Wheels and tire combinations...
Click Here
Reply
Old 06-15-2004, 02:49 PM   #1
AleXb
AleXb's Avatar
AleXb 28/M
Send a message via AIM to AleXb
Default Tried searching, but can't find exact answer....19" Whe
I am so lost.... What do i have to do in order to not worry about rubbing at all with 19" rims?.... I plan on using Tanabe DF210 springs for a 2" or more drop and the 5Zigen 19" Hyper 5ZR's.....
-Should i run 19x8 front and back?..... or staggered 19x7.5 front and 19x8 rear?...
-Should i run 19x7.5 front and back so rubiing isn't an issue?...
-What size tires to run with those three setups?.... so i don't rub while turning all the way.....
-What Offset to run?
I am pickin up these wheels in like a day or two so quick responses would be highly appreciated....Thanx soooo much guys
-Alex B.
_____________________________________
Keepin it clean and low....
AleXb is offline   Reply With Quote
Old 06-15-2004, 08:44 PM   #2
aero2424
aero2424's Avatar
aero2424 113/M
I'm in the same boat...
19x8 w/215s needs what offset? I've seen 35,40,42, 45
or..
19x7.5 needs?
aero2424 is offline   Reply With Quote
Old 06-15-2004, 09:31 PM   #3
XBOXED
XBOXED
Send a message via AIM to XBOXED
if you run 19x8 run a 40-42 offset and if you run 19x7.5 run 40 offset
as for tires.... dont go larger run 215/35/19 thats a great size that will give minimal rub
TOO YOUNG AND TOO FAST!!!!
XBOXED is offline   Reply With Quote
Old 06-16-2004, 01:37 AM   #4
wickedchimp
wickedchimp
So 19x8 with 45 offset is too much?
wickedchimp is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
