how much would this stick out?
Old May 29, 2006 | 05:46 AM
bbsukidesu's Avatar
Default how much would this stick out?
i'm thinking about getting 15x9 -7 offset wheels. would these fit with fender rolling (i got DF210's)?
if not what could i do to make it work?
if they do fit how much would they stick out in the front/back?
thanks ahead of time.
aaron.
Old May 29, 2006 | 06:34 AM
Boxer_Rebellion's Avatar
They will stick out like crazy. Look at the posts with the new SportMax 15x8's, zero offset... yours will stick out more as they have over 20mm overall width.
Here's a pic of 2tone's with the 15x8s... he' also running OTG spacers in back, which you may have to do also to clear the rear arm.
Old May 29, 2006 | 06:39 AM
magicmanjk808's Avatar
aaron, you are nuts unless you getting the flares like you wanted.
Old May 29, 2006 | 11:07 AM
bbsukidesu's Avatar
i am planning to get the flares i want. gonna be a while til i get everything though.
Old May 30, 2006 | 08:09 PM
bbsukidesu's Avatar
bump. would i have any rubbing issues?
Old May 30, 2006 | 08:42 PM
2tone_xB's Avatar
your springs are probably
a 2" inch drop, so most likely you'll rub.
i have coils with a 2" drop.
rub like crazy with passengers.
and with that offset,
i'd say flares are a MUST.
Old May 31, 2006 | 02:13 AM
bbsukidesu's Avatar
will they still rub even if i roll the fenders?
Old May 31, 2006 | 02:18 AM
blackwagon's Avatar
yes.... if 8 inches rubs so will 9 but i say do it!!! whats a lil rubbing anyways
Old May 31, 2006 | 04:57 AM
05_camo_boxb's Avatar
k a little off subject but argh lol..anyways what is the setup you have 2tone.. i wanted to get the same wheels..sport max with the o offset... but want to know if i can use my stock tires and im lowerd on rsr's will work ...id like to get some 3 degre camber or more if needed to sit flush.... so i want the same wheels with stock tires and camber will that work ....?
Old May 31, 2006 | 09:04 AM
yes, it will work.....
back on topic....yes aaron, you will rub. -3 or -5 camber will not let those fit under stock fenders. let me do more fender work on my car and i'll let you know what you can do.....
Old May 31, 2006 | 09:41 AM
bbsukidesu's Avatar
thanks!
Old May 31, 2006 | 10:46 AM
backstb01's Avatar
you should stick out about 15-19mm out of the fender
Old Jun 1, 2006 | 04:38 AM
bbsukidesu's Avatar
yes... thats what i was looking for ^
thanks.
Old Jun 1, 2006 | 07:21 AM
thankx for thehelp will be shoping soon
Old Jun 3, 2006 | 08:12 PM
bbsukidesu's Avatar
update: went to the shop for the wheels and they said they dont make them anymore.
Old Jun 4, 2006 | 01:05 AM
what you was looking at?
Old Jun 4, 2006 | 01:13 AM
Silencei2's Avatar
In my opinion, get flares first and get your suspension all setup before you go with super wide tires. I got low offset Work Equips with Tein Super Street Coilovers and I went through a pair of tires for the rears in less than a month. After a pair of tires and a couple hundred dollars on a camber kit I still rub minimally with my fenders trimmed and slightly rolled.
Also! get functional fender flares so you can actually cut up the rear fender and fit those monster wheels under there.
Hope my experience helps you out
-Rich
Old Jun 4, 2006 | 01:38 AM
bbsukidesu's Avatar
-Rich
thanks. this will help me out significantly. what kind of flares do you have? how much was the bodywork to trim your fenders?
i will pm you.
Old Jun 4, 2006 | 09:08 AM
05MATCHbox's Avatar
what size are the falken ziex's in the picture above?
Old Jun 17, 2006 | 04:30 PM
qbqt's Avatar
It may not rub if you have a stretched tire on it. It depends. Is there an actual pic of the rim with that offset, maybe on another car? I dont mind if it sticks out an inch, as long as the fender almost covers the tread(not the sidewall).
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
