bazooka subwoofer TUBE problem
Old Jun 5, 2006 | 05:15 AM
steve_r's Avatar
Default bazooka subwoofer TUBE problem
hi i recently ordered a bazooka bta10200 from an ebay store called "the deep discount." its a powered 10 inch tube with a 200 watt rms mosfet amp.
i got it next day. had a friend help install it. took about 3 hours to get to the moment of truth. it didnt work so we spent another 3 hours troubleshooting. speaker connections seem fine, power connections seem fine. couple days later i decided to do a little test.
my friend has a bta10200 in his tC too, so i tried swapping. he put his in my car with my connections and it didnt work. i put mine in his car with his connections and it didnt work. logically this means theres something wrong with my connections, and on top of that, the sub is defective, right?
P.S. does anybody know if this bolt is an accepted grounding point:
when you open the trunk behind the middle seat you pull the black flap down and it's the first bolt you see, sort of gold in color.
Old Jun 5, 2006 | 05:40 AM
SquallLHeart's Avatar
uhh.. if it's connected to the chassis... it's a ground... you can use pretty much anything for a ground point.
Old Jun 5, 2006 | 12:53 PM
SCI_TC_GUY's Avatar
and as long as it isn't a painted surface... if it is, hit it with a little 60/80 grit sandpaper
Old Jun 5, 2006 | 07:22 PM
steve_r's Avatar
i got a multimeter and the power connection is just perfect.
UPDATE: i opened the unit up myself and found a blown 20 amp fuse. i replaced the fuse but still found no power using a multimeter between the 2 fuse connections.
im going to try my friends sub in my car again after i reverse the polarity of the speaker wiring.
DOES IT MATTER WHICH WIRE IS USED BETWEEN POSITIVE AND NEGATIVE FOR SPEAKER LINE LEVEL INPUTS?
Old Jun 5, 2006 | 07:46 PM
SCI_TC_GUY's Avatar
yes, it does matter, but that would just make funny sound, not keep it from working completely
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
herwig
Mar 23, 2015 04:19 AM
toyotaisme
Jan 10, 2015 10:24 PM
Itsdchz
10
Jan 16, 2004 11:37 PM
Al-Truistic
Jan 16, 2004 04:58 AM
