as i posted in your other one. its a double post. and BUMP cause id like to know how to remove this too.. just goo gone? i tried heating and prying it out but it was hard as hell to get out soooo there goes that idea..
These questions have been covered before. Removal is easy...heat emblem, use floss or fishing line in a 'sawing motion', just be careful of the alignment pins on the front and rear "Scion" emblems. You can use Goo-Gone to get the left-over adhesive off your car, but its not necessary. To put it back on, you can use heavy duty automotive double-sided adhesive or a silicone adhesive. To actually paint your emblems, you're going to have to SEARCH for that one!
__________________ MGS4 "Spotted" tC (Thanks Jeff!) Photos located "HERE" and "HERE". My tC; Simple, Clean, and...Fresh.
mine got jacked by goo gone.. or maybe it was the paper towels... HAHA... def the paper towels.. i dunno.. i got some polish.. i'll put that on... just dont use a paper towel.
Does goo gone have any effects on our amazingly durable paint finish?
As mentioned in the link above............yup, you might get adverse effects on your amazingly durable paint. I wouldn't know, and in that same token.......wouldn't dare
"If something's broke, fix it. If you don't know how, learn. If you're not willing to learn, don't complain about it. If it can't be fixed, then accept it, and move on."
goo gone is harmless, as long as you use caution, and not a lot. Also, once you take off the emblem, wash the area with car soap and water, then put a coat of wax in that area to make sure it stays protected (just for safe measures)
ive never had any problems and I've done it a good 15 times.
05' tc FM
780 watts /// 2 12" Alpine Type S Subs
CC Short Shifter
Blacked out Emblems
TRD Exhaust
TRD Springs
Put the goo gone onto a towel first. Don't apply it directly to the surface, and therefore, you won't be able to miss any and leave it on your paint to ruin it.
goo gone is very abrasive and can take off clear coat. but if you're just taking off an emblem you won't use enough nor have it on the car long enough to have any negative effects
