Regional - Deep South AL, AR, LA, MS
Well I got the box stripped (some pix)
Old Jul 13, 2006 | 08:01 PM
scionturtle's Avatar
Default Well I got the box stripped (some pix)
I never have enough time to do a project from start to finish so it took about 2 weeks to see this to completion. I did of course go on vacation in the middle of all of it.
It seems like about 20 minutes before you finish a project you find out the "right" way to do it. In my case it was the discovery that the rubber trim inside the window frames is not glued in and pretty much just peels right out. Knowing that I would have finished about an hour after I started. Oh well its done. It was a pain in the ___ and my fingers were very sore but it looks
FREAKING AWESOME
Here are the pics before:
And After:
But be careful cause one slip .....
And you will be calling the "Chip Medic"
That's All Folks!!!!!!
Tom
Old Jul 14, 2006 | 07:15 AM
OldYeller's Avatar
OUCH--good work except that last picture!!!
Old Jul 14, 2006 | 07:17 AM
RedneckwithanxB's Avatar
im doing this this week, but i have to get rid of the tint soon
Old Jul 18, 2006 | 11:01 PM
scion4ever's Avatar
So last night i got curious and started removing mine. It is a pain in the butt!!! Anywho, i was wondering the technique you used to remove it. Im just peeling off chunks and its not going to good. Looks awsome by the way!
Old Jul 19, 2006 | 08:38 PM
superfreestyle's Avatar
DeepSouth Scions
man... you are so hardcore!!!
make the xB look naked to me... to each his own i guess
Old Jul 20, 2006 | 03:35 PM
Default box is stripped
At first I just pulled and tugged and pulled off little pieces at a time. As I said in the start of the post, you always figure out the easy way to do someting 30 minutes before you finish so to those who are interested... I would recomend getting a plastic putty knife or two and than on the outside of the frame try to peel up the edge by catching it with the putty knife and try to get about an inch or so peeled back to give you a finger grip. Than on the inside of the window frames pull out the rubbber around the window about 6 inches at at a time and strip it from one side to the other. Be careful though because there is at least one spot where the rubber is glued in and its tough around the window clips on the front. The real problem areas are around the fixed vent windows on the back door. Man I hated that. Also the area around the mirrors is a bear as well. Good luck its a pain but everyone, except a few people without a sense of style and no taste, that has seen it says it makes the ride look so much better.
Later
Tom
Old Jul 20, 2006 | 09:47 PM
DeepSouth Scions
Default Re: box is stripped
Later
Tom
the mirrors come of in about 3 minutes a peice with a #2 phillips head and a 10mm socket...
same with the rear windows that do not roll down... i removed my rear fixed door windows for tinting, they are tinted completely even 5 or so inches down into the door and the edges are filed with no edge gap whatsoever just like the rest of my windows
Old Sep 1, 2006 | 12:17 AM
greenenvy1636's Avatar
It looks great! I'm still learning all the cool things that we can do to our xB's.
Old Oct 10, 2006 | 01:25 PM
g9deal10's Avatar
Default Affiliate Manager Wanted!
Affiliate Manager Wanted! Over $6,000/month http://filthyloaded.com/ci
Old Oct 10, 2006 | 02:06 PM
zereaux's Avatar
Revolt Imports
DeepSouth Scions
yhwhdesign
Jun 11, 2021 03:34 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Bimfi
Sep 4, 2015 08:15 PM
Daddyfredregill
Aug 18, 2015 01:31 PM
excessads
Jul 13, 2015 11:41 AM
