Front sway Bar for 2006 XB
Old Aug 5, 2006 | 06:03 AM
swede's Avatar
Default Front sway Bar for 2006 XB
Is there a front sway bar for the 2006 XB.
Old Aug 5, 2006 | 07:20 AM
SquallLHeart's Avatar
yes.
hotchkis and cusco
Old Aug 5, 2006 | 12:56 PM
xBHAWK's Avatar
Default ....Aftermarker or OEM?.....
Is there a front SWAY bar available aftermarket? YES ^^^^
OR..
Does the XB have one installed from the factory? Yes ....
I was going to spring for a new set of sway bars.
Then I found out that the XB has a thick front sway bar.
It has wimpy bushings, that I replaced with poly-urathine bushings. See the thread link and photo below.
https://www.scionlife.com/forums/vie...=asc&&start=25
My butkiss tells me that the bumps are muted in the front now.
All you need is the bushings and a rear sway bar
Old Aug 5, 2006 | 02:44 PM
jct's Avatar
jct
also swaping out your sway bar bushings to polyurathine will help alot also!!!
Old Aug 5, 2006 | 03:49 PM
Tim_Carr's Avatar
Yep, xBHAWK is right on. Go grab some bushing's, swap them out and presto! You will be surprised what a difference a good stiff bushing make's. The sway bar in the front is fine. The strut tower stabilizer and bushing kit and it will stiffen up the front end plenty. Get a rear swaybar, then it will drive like a slot car.
Old Aug 5, 2006 | 08:01 PM
swede's Avatar
Where do you buy the bushings?
Old Aug 5, 2006 | 08:16 PM
swede's Avatar
Does anyone know the part number, because on energry suspension's website the Scion is not listed, so I am not exactly sure which bushings to order.
Old Aug 5, 2006 | 08:32 PM
evosky's Avatar
yeah, can anyone recommend bushings for the front sway ?
thanks for the info guys !
Old Aug 5, 2006 | 08:47 PM
xBHAWK's Avatar
Default ....The details...
I just went through this mod, so I can clear up some confusion.
Jethro spent the least, he just bought the bushings at an autozone. Take these bushings to the hardware store, buy 2 grade 5 bolts that are 4 inches long. Check thread length, you need at least an inch of threads. Get nylon lock nuts for those 2 bolts. I bought the kit mentioned above from SUNMMIT. I had to replace the bolts anyway, so save yourself some money.
Bushings are bushings, very universal. ( See photo above.)
See the other thread's link and check out other pictures.
Old Aug 5, 2006 | 09:19 PM
swede's Avatar
Cool Thanks, That makes more sense. Also, do you need a spacer between the bushings or is it okay to just have the washers touching. I am asking because I want to make sure that the stabalizer bar and control bar are parallel. How do you know how much to tighten the bolts? The bushings are the "Energy Suspension" Performance End Link Set, right?
http://www.energysuspension.com/pages/endl.html
Old Aug 6, 2006 | 01:59 AM
TJ's Avatar
TJ
Try this link http://store.summitracing.com/partde...0&autoview=sku
Then buy a 2 4 inch grade 8 bolts and nuts and tighten it. They also have bushing kits for our rear shock absorber .... You might want to check that out also.
Old Aug 6, 2006 | 01:25 PM
xBHAWK's Avatar
Default ....BEEFED BUSHINGS.....
^^YES, TJ's link is what you need!!^^^^
The KIT's instructions say to torque the nut to 13 LBS.
The rear shocks should be replaced with Monroe Sense-a-trac 5987 shocks with or without bushings.
No spacer needed with these beefed bushings, see photo above.
The bushings come with washers. Line them up as shown and attach sway bar to lower control arm with bolt, bushings and nut.
This set is another that will work:
Performance End Link Set-
(Grommets and Washer Set)
Old Aug 14, 2006 | 07:19 AM
bB2NER's Avatar
Music City Scions
Here is the part number I got from AutoZone. Energy #9.5164R Most AutoZones should stock them or be able to get the next day from their warehouse. Then just get 2 grade 5 4inch long bolts and 2 nylock nuts. Total mod cost was under 20 bucks.
WOW! I just checked that Summit link and they have the same pieces damned cheap. That's about half what AZ wants. If shipping isn't more than 5 bucks you could save a few more bucks going that route instead. Good find indeed!
Old Aug 14, 2006 | 07:29 AM
bB2NER's Avatar
Music City Scions
I just tightened mine till the bushings started to squish. Then counted the number of threads showing so I could make the other side match. You will notice an improvement. This is a MUST do Mod IMHO!
Squishface
Sep 15, 2015 06:51 AM
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Jan 9, 2015 02:26 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
yamahamx117
Dec 25, 2014 01:54 PM
