Garage tricks...they can help??
ok the first trick is the timming 2 or 3 degrees more...does it help?
anotherone, to eliminate the line of water to the throttle.
to put highter injectors cc
to eliminate some vacuum
ground kit
people which one of these do you recomend, those are tricks of other cars, and don't know it it'll help...this doesn't mean i will do it...just some of you also have this doubts, they are not HP tricks (to make myself clear) chkt
ground kit
1. As far as these garage tricks go, some have a small effect and some don't. Adding a few degrees of timing in the old days was as simple as readjusting the distributor. Our Scions use a crank shaft sensor. It has preset timing pattern that is controlled by the computor. There are some piggyback controllers that have limited success. Other option is using offset key to advance the sensor timing ring on the crank, if it is even possible.
2. As far as the water lines to the throttle body, (I just looked at mine and can't really tell what the lines are on the bottom ) Look at a website www.gassavers.org and you will find an article about using Hot Air Induction instead of cold air induction to increase gas mileage.
3. Higher capacity injectors are not needed unless you are running a lot of boost with a supercharger or turbo.
4. I can't think of any reason to eliminate some vaccum. A lot of your controlls operate off of vaccum. Heat and Air vent controlls as well as engine controlls.
5. I installed a ground kit on mine and saw no difference at all. Some people say it smooths the idle on theirs, others are like me and saw no change.
Hope this helps answer your questions.
1)timing is done by ecu and sensor, can be changed a bit but ecu just compinsates
2)The water lines to TB keep it from icing up
3) actually the more vacuum the better the gas milage, but it only get up to between 18 and 22 ( the old fuel meters used vacuum to tell you either you were good power or good gas mileage)
4) with larger injectors w/o boost it won't idle ( some don't even run) and if they are just a bit bigger the ecu again changes to meet the rich mixture it reads.
5) some have had success with ground kits, others not ( think it's 50/50). you can see for your self by putting one on.
All in all, ground kit is the only thing that won't screw something up ( unless it is installed improperly)
so an APEX, could control the hole car, so i must play with it...hmm interesting, also to control the vvt-i uses the same piggy??, for more updates i will post them, for those of you who are curious about these cars even though they are not for racing...
ground kit
ground kit
All of this sounds great!!!....if you really want to ruin your car.
This is all old timey car stuff. Your ecu will throw all kinds of lights and/or codes at you if you do this stuff. With cars like these- the ECU runs the show, not you.
The ground wires shouldn't hurt, but don't really do anything (I know because I have them).
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
