Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Suspension & Handling
Register Forgot Password?
Reply
Old 07-21-2004, 01:05 AM   #1
scionlife
Founder
Admin Emeritus
scionlife's Avatar
scionlife 38/M
Default Spring Installation on Scion xB
CREDITS: Written by nacy333. If you used this article and it helped, shoot him an email or a PM and thank him! Big credit goes out to Randy West. As well as being a big time **** star back in the 80s, he also really knows his stuff when it comes to this. He's done 32 sets of springs now and continues to provide a big service to So Cal Scion owners...remember, he does it for free for TSW members. Also thanks to Ernesto for providing the testing vehicle. And to Kristal (Randy's wife) for keeping the beer cold and making fun of us while we worked out stuff. Again, if you don't feel confident in changing your springs and are in the SoCal area, just PM Randy (he's gonna set a world record ya know).
DISCLAIMER: Scionlife.com does not take any responsibility in what you do to your car. This FAQ could be filled with incorrect information. You could be voiding your warranty if not installed by a certified mechanic or dealership. It is quite possible that you can totally mess up your car by using this as a guide to install your springs. This can result in serious bodily injury, death, dismemberment, sexually transmitted diseases and so forth to you and anybody else in case of an accident resulting from failure to take safety precautions and/or following the instructions in this write-up.
Get Ready:
Nut Sizes: 12mm, 14mm, 17mm, 19mm
Tools: Floor Jack, Jack Stands, Sockets and Wrenches in above sizes, Flathead Screwdriver
Optional: Latex Gloves, Impact Wrench, Corona Extra, Tylenol, Toyota Mechanic
Buddies Required (Not including yourself): One (you can have more but they will only make fun of you, drink your beer and eat your snacks)
Rear Installation:
1. Once you get the rear of the car jacked up, it is not necessary to take off the rear wheels, you can do it without doing so but it makes it alot easier, especially if you don't know what you're doing (as evidenced in the following pictures).
2. Once you have one side of the rear up take off the Shock nut (17mm) that attaches the Rear shock and Suspension.
3. Once you've taken off the nut, proceed to 'jiggle' the shock loose of the bolt that it is attached to until it is completely off.
4. If you have the whole rear of the car lifted, just pump the jack a few more times and the springs should pop right out, if not push down on the rear brake drum brake body and have your buddy (see requirements) pull out the spring.
5. Remember to take care full note of which way the rubber grommets fit back in the assembly before you remove the springs completely. The top grommet should have the indented holes section facing upwards.
6. When placing the new springs into the assembly be sure that it aligns with the top rubber grommet to fit in place with the stop on the grommet.
You can now put the rear suspsension back together. See how easy that was?! Just take note that as with the front, springs will not settle into the proper drop right away. In most cases, it takes about 2 weeks to properly settle to the proper height, though most of the rear will settle while you're working on the front springs.
Front Installation:
First things first. Do you have an air gun to undo the big nut (god I love that term!) in the front strut? If you don't, or hell, even if you do, I would recommend loosening the strut nut that compresses the spring down before you remove the front strut assembly - you'll see why later in this FAQ and I'll point it out before you have to.
As usual, we are not going to go into detail on how to jack up the car and remove the wheels, but you better do it now before you go to the removal steps. Put the car on jack stands so it doesn't fall on your face.
1. Under the hood: Remove the rubber dust cap that covers the top of each strut tower.
2. If you are using hand tools then you should start by loosening the large 17mm nut a bit to make it easier in the long run. If you don't do it now then its a real pain in the ___ later. Just loosen it a little, don't remove it!
3. Remove the nuts (12mm) at the top of the struts. The one hiding in the rear is a real pain in the ___ though and cannot be removed with a normal socket wrench. Manual labor time.
4. Disconnect the front brake line housing that attaches it to the front strut by removing the bolt (14mm) in this picture.
5. Use a flathead screwdriver to undo the clip that holds in place the ABS sensor line.
6. Use a 19mm socket to remove the 2 lower bolts that attaches the strut to the lower arm.
7. Disassemble the strut and lower arm assembly and remove the strut from the car.
8. The front strut is now off the car and randy goes for a little finger dip action where its nice and lubricated (not neccessary and completely optional). You'll need to remove some of this lubricant when you remove that big nut(!).
9. While holding down the front strut firmly in place go ahead and remove the big nut from the front strut. *When the nut comes off, part of the assembly will spring out, do not be surprised and take precaution as to where both ends of the strut are pointed.*
10. Be sure to take note of the order of the front strut assembly. It's the strut rubber housing, the metal plate, a paper-like thick bushing, and the top plastic housing.
11. When putting the new spring in, make sure that end meets up with the lower stop on the strut.
12. The arrow on the rubber housing should be point outward of the car - in this case, facing in the same direction as those 2 forks on the lower part of the strut (the ones that hold the lower part of the strut to the lower arm).
13. When you place the top metal portion of the strut assembly on, make sure that the side labeled 'OUT' is facing the outside of the car (same as with the rubber boot cover housing).
14. When you're done with that, place on the paper-like bushing and then the top of the strut assembly housing on the strut and have someone push down on the assembly while another places the big nut back in the strut.
15. Go ahead and tighten up the big nut, you do not need to do this all the way as you should tighten it more after you've placed the strut back in the car.
16. Put the strut back in. It helps while someone holds it down in place on the bottom while someone helps to guid the top strut into place.
17. Place and tighten up the screws that hold the top of the strut into place.
18. Replace the bolts that attach the shock assembly to the suspension. They should be inserted in the front and the nuts secured to it from the rear like the top not in this photo. (from the front passenger side)
Anyways, after you put into place the two lower bolts that hold the strut to the lower arm, remember to put the ABS sensor line back on the clip and to bolt on the front brake line housing to the strut. Once you've done that you're all done and you can continue to the other side!
scionlife is offline   Reply With Quote
Old 07-21-2004, 01:37 AM   #2
Back_In_Black_xA
Back_In_Black_xA's Avatar
Back_In_Black_xA 30/M
Send a message via AIM to Back_In_Black_xA
Wow the rear is much easier than I thought it would be. The Toyota instructions tell you to even undo the brake line and all that crap. But apparently one bolt is all it takes on each side to take out the spring.
Back_In_Black_xA is offline   Reply With Quote
Old 07-21-2004, 04:02 AM   #3
randode
Wagonistas
randode's Avatar
randode 38/M
Quote:
thats so they can charge you 4 hours labor.
www.randode.com
Air Suspension | Lighting & LED Swaps | Metal Fab | CNC Plasma Cutting
Air Stunner Elite struts by Randode now available
*100% fabricated strut housings *KYB GR2 inserts *UA Aero Sport bags *spherical top pivots *camber adjustment *made in the USA *available for xA/xB, Gen2 xB
randode is offline   Reply With Quote
Old 07-21-2004, 04:06 AM   #4
az_pinoy
az_pinoy's Avatar
az_pinoy 32/M
Send a message via AIM to az_pinoy
i'm actually gonna put this guide to use tomorrow ;)...pray for me...j/k
JC
"The desire to succeed means nothing without the will to prepare"
www.camelbackscion.com
www.autofashionusa.com
www.scionetics.com
az_pinoy is offline   Reply With Quote
Old 07-21-2004, 04:09 AM   #5
randode
Wagonistas
randode's Avatar
randode 38/M
Quote:
JC
dude, call me up if ya get stuck. i'll walk you through it.
www.randode.com
Old 07-21-2004, 04:12 AM   #6
az_pinoy
az_pinoy's Avatar
az_pinoy 32/M
no prob man ;)..will do
JC
www.scionetics.com
Old 07-21-2004, 11:49 AM   #7
Dwestxb
Dwestxb's Avatar
Dwestxb 39/M
Send a message via AIM to Dwestxb
I will be doing this today, I will be calling you if I have any problems.
Dwestxb is offline   Reply With Quote
Old 07-23-2004, 01:38 AM   #8
Dwestxb
Dwestxb's Avatar
Dwestxb 39/M
Randode is the Scion King!!!! Instructions were very easy to follow and very detailed. Don't waste your money paying $300 & up for the dealer or shop to install. If i could do it, anyone can.
Old 07-23-2004, 05:11 AM   #9
its_ikon
its_ikon's Avatar
its_ikon M
Send a message via AIM to its_ikon Send a message via Yahoo to its_ikon
i looked at this for reference when i did my spring install. the rear literally only takes about 20mins total. it consists of two bolts.
X
its_ikon is offline   Reply With Quote
Old 08-15-2004, 06:17 AM   #10
WileECoyote
WileECoyote
Its even easier to do the front suspension bolts (3 on top per strut) when you take out the windshield wiper assembly and tray.
Then you can use sockets on all 3 bolts instead of working hard with those manual tools. The tray comes out very easily!
...genius...super genius...
WileECoyote is offline   Reply With Quote
Old 08-23-2004, 01:55 AM   #11
sparkysong
sparkysong
Default spring install
super clear, super simple directions. i read them over 3 or 4 times and then lost them. i think i must have left them at work or something. instead of looking them up again, i decided to use the force and just go for it. my 12 year old son and i cranked it out in less than 2 hours. the springs we installed are tanabe df210s. they dropped the xb perfectly (around 2 inches) and retained much of the stock ride. thanks for the great info!
mark
sparkysong is offline   Reply With Quote
Old 08-31-2004, 08:36 PM   #12
racer8422
racer8422's Avatar
racer8422
What happened to the bump stops? My Eibach Pro-kit came with two bump stops for the front springs. Instructions say to replace them with the Eibach ones. Did I just miss it? :
racer8422 is offline   Reply With Quote
Old 09-01-2004, 08:08 AM   #13
nacy333
nacy333's Avatar
nacy333
Send a message via AIM to nacy333 Send a message via MSN to nacy333 Send a message via Yahoo to nacy333
Quote:
When we had originally did up this little FAQ there were no springs out on the market that included bump stops. If however, you received bump stops with your aftermarket springs, by all means replace your factory bump stops with the aftermarket parts.
Is it the same?
nacy333 is offline   Reply With Quote
Old 09-01-2004, 08:11 AM   #14
BLKScion
BLKScion's Avatar
BLKScion 110/M
Send a message via AIM to BLKScion
awsome instuctions...thanks alot, although id perfer New Castle over Corona, the intruction will come handy next week when i install my springs..thanks again!
_Ryan
'04 Black Scion xB
'05 Honda Element
BLKScion is offline   Reply With Quote
Old 09-01-2004, 08:31 AM   #15
nacy333
nacy333's Avatar
nacy333
Quote:
_Ryan
I've lost my love for Newcastle, and have diverted my affections to the new newcastle...Heffeweisen, though I'm slowly being tempted away by Stella.
Corona, however, will always be my steady.
Anyway, I'm just waiting for Randy and Krystal to head back to California for vacation one of these days so we can get drunk again so we can get drunk and make up something to install.
Is it the same?
Old 09-01-2004, 02:53 PM   #16
randode
Wagonistas
randode's Avatar
randode 38/M
Quote:
soon my friend, soon.
www.randode.com
Old 09-08-2004, 11:54 PM   #17
WoogieFresh
WoogieFresh 36/M
Send a message via AIM to WoogieFresh Send a message via Yahoo to WoogieFresh
Default A Sincere Thanks!
I just finished installing Tein S.Techs on my xB and I must say that this walkthrough was amazing! Thanks a million!
WoogieFresh
WoogieFresh is offline   Reply With Quote
Old 09-28-2004, 10:13 AM   #18
hotbox05
hotbox05 29/M
mertechperf mertechperformance@hotmail.com
Send a message via AIM to hotbox05 Send a message via MSN to hotbox05 Send a message via Yahoo to hotbox05
anyone got any instructions for doing this with adjustable coilovers? how hard is it gonna be without air tools?
13k posts and counting
'06 Suzuki RMZ450
'74 Honda CB550 K0
'98 Honda VTR1000F
'08 Honda Ruckus
'10 Honda Elite 110
merTECH www.teamnvs.com JDMPalace
www.totalruckus.com
hotbox05 is offline   Reply With Quote
Old 09-28-2004, 12:10 PM   #19
Huskersnow
Huskersnow 36/M
I told you last week at the meet to search the tech section. Anyways here it is.
http://www.scionlife.com/forums/viewtopic.php?t=20764
Quack Quack
Huskersnow is offline   Reply With Quote
Old 09-29-2004, 04:20 AM   #20
hotbox05
hotbox05 29/M
nah man thats a different setup and my damn front coilover sleeves arent big enough to get around the portion that secures the insides of the strut from coming apart. i guess theyre just crappy. my loss i suppose too bad now my back is dumped and my front is at stock height
'06 Suzuki RMZ450
'74 Honda CB550 K0
'98 Honda VTR1000F
'08 Honda Ruckus
'10 Honda Elite 110
www.totalruckus.com
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
air, bump, coilover, diy, drop, install, installation, installing, price, replace, rubber, scion, setup, sleeves, spring, springs, suspension, tanabe, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
