misshifted and redlined at 8000rpms
Old Oct 8, 2006 | 10:38 PM
vvti24's Avatar
Default misshifted and redlined at 8000rpms
I was flooring my car the other day and i misshifted from 3rd going to 2nd instead of 4th.... I have the twm stage II shortshifter and its really easy to misshift... What can check to make sure my engine is okay? when i misshifted i heard a loud bang and snap under the car... I'm just worried that i might blow a rod outta nowhere...
Old Oct 8, 2006 | 10:48 PM
tCizzler's Avatar
I did the same thing once, but i hit reverse instead of 4th. Loud crack, 30 foot strip of rubber on the road, engine stopped and then restarted on its own, scared the ____e out of me, but that was about 2 months ago, and everything is fine. I guess thats toyotas quality
Old Oct 8, 2006 | 11:09 PM
tikbhoy's Avatar
if theirs no pistons sticking out then your half okay.
compression check is a must.
3 -> 4 shouldnt be a problem, maybe you were leaning on it.
Old Oct 9, 2006 | 12:25 AM
mattvs's Avatar
compression test and a leakdown test..
never do it again.
you're lucky you didnt drop your transmission onto the highway :p
Old Oct 9, 2006 | 12:56 AM
eLpReSiDeNtE's Avatar
tC squad
and dat is one of the reasons why i drive an automatic...lol
Old Oct 9, 2006 | 12:59 AM
XtCFast's Avatar
lol i thought u cant go into rev after u hit 3rd or sumtin like that. Now im scared =(
Old Oct 9, 2006 | 01:17 AM
SquallLHeart's Avatar
well. i had a friend went from 5th --> 2nd
engine didn't survive...
compression test is a must.
Old Oct 9, 2006 | 01:30 AM
vvti24's Avatar
well thats the second time it happened.. the first time happened at the track about 3months ago.. i was nervous as ____ goin down the track for the first time.. so i fukked up
Old Oct 9, 2006 | 01:31 AM
vvti24's Avatar
where can i get the compression checked?? at the dealer??
Old Oct 9, 2006 | 01:35 AM
tC squad
once again AUTOMATIC!!!!.....lmao
Old Oct 9, 2006 | 01:46 AM
dealer.. any good car shop.
Old Oct 9, 2006 | 01:59 AM
tikbhoy's Avatar
Originally Posted by vvti24
well thats the second time it happened.. the first time happened at the track about 3months ago.. i was nervous as poop goin down the track for the first time.. so i fukked up
if its a drag strip it be best to use the brakes
Old Oct 9, 2006 | 02:05 AM
tC squad
i still say AUTOMATIC!!!!!lmaoooo....im juss being a pest dont mind me people!
Old Oct 9, 2006 | 02:15 AM
^^ i think you're trying to compensate for something
j/k...
Old Oct 9, 2006 | 02:48 AM
Neothin's Avatar
they make DIY compression testers if you wnat to go to autzone or something like that
Old Oct 9, 2006 | 03:00 AM
tC squad
j/k...
is it dat obvious???....hahahah u should see my shift boot conversion....damn i wish i had a picture...lmao
Old Oct 9, 2006 | 03:07 AM
paul34's Avatar
Always, always, always handle the shifter with an open hand! That way, if anything, you will overshift and that is NOT anywhere as near of a problem as money$hifting!
Also, don't bang the shifter into gear - that way, you'll feel the resistance from the synchros when you do something like 3rd-2nd and you'll instantly know something is wrong
but lesson learned, and you are ok, that's what counts
BTW, you can't get into reverse while you're moving forward. Even if somehow you managed to make it happen, everything (everything) in your drivetrain would literally explode.
Heck, in our cars if you're moving even 1 mph forwards you'll thump into reverse (not good), anymore than that and can you say GRINNDDD
Old Oct 9, 2006 | 03:10 AM
flintgauge86's Avatar
Dude, you went into reverse... You would have had to push the shifter very hard to get it into reverse at those speeds. IT's amazing the whole tranny didn't fall out rite then and there. VVTI24, you said you've done this twice? OMG, that's not good man. You need to work on your shifting. I did it once when I had my tC, 3-2 instead of 3-4 at about 70 mph, it redlined real hard and chirpped the tires. I had the car another 10 months and never had a problem. Those toyota engines are bullet proof! Relax, and don't ever do it again or you loose your scion privilages. And elpresidente, quick knockin' everyone with a stick. Don't hate the third pedal!
Old Oct 9, 2006 | 03:11 AM
engifineer's Avatar
You are probably ok. If you take the time to do a compression test, do a leakdown test as well. That will tell you a lot more.
Old Oct 9, 2006 | 03:19 AM
he's just jealous and trying to feel better about it..
and yeah.... you don't need to put any pressure horizontally on the shift **** at all... seriously... going from 2nd to 3rd.. and 3rd to 4th should be effortless...
