Tach Wire
Old Oct 12, 2006 | 06:31 PM
soros151's Avatar
Default Tach Wire
I have an aftermarket tach lying around, and thought of using it just for the shift light it has in it. I was wondering exactly where to tap for the tach signal. The tach has 4 wires,
Red, Black Green, and Yellow. I know where the red and black goes to, but where does the green and yellow go. and where is tha tach signal wire? Photos would help a LOT. Thanks in adavance guys, and yes I do go every week to the strip and yes I do need the Shift Light.
Old Oct 13, 2006 | 11:23 AM
soros151's Avatar
bump...
Old Oct 13, 2006 | 12:07 PM
Borisimo's Avatar
Maybe this thread will help: https://www.scionlife.com/forums/viewtopic.php?t=130218
Old Oct 13, 2006 | 12:10 PM
soros151's Avatar
Originally Posted by ProshopXB
Tach- Black wire data link conn. under dash, pin 9 or the tach wire is also found at the ECM behind the glove box, top plug, pin 5.
and this is what? I don't get it. That's why I made this post, cause I couldn't understand this.[/quote]
Old Oct 13, 2006 | 12:19 PM
ProshopXB's Avatar
soros151 do you know where your OBD2 scanner plug under the drivers side dash is? If you pop your head under the dash you will find a little black plug... Look for a black wire on it.
or
You can pull your glovebox out and behind it will expose the factrory ECU on the right hand side. On the very top plug is the RPM wire... see the link below and where it says "I" that is the RPM wire.
http://www.zeropointindustries.net/i...em-ult-web.gif
Old Oct 13, 2006 | 04:03 PM
soros151's Avatar
At last, a very specific answer. Thanks!
Old Oct 15, 2006 | 02:38 AM
soros151's Avatar
Okay, tried looking for either the black box, or the black wire, but no luck there, so I took some pics to see if someone can pinpoint the exact location or at least a nearby place where I could find that wire. So...
Here is an upside down pic of the ECU without removing the glovebox compartment.
and can someone plase tell WTF is this?
Old Oct 15, 2006 | 02:43 AM
ProshopXB's Avatar
The white plug in the first pic, below the fuses is the OBD 2 plug... In the pic of the ECU it is the farthest plug away or all the way to the right in it.. refer to the diagram I posted above and look for pin labled as "I"..
Old Oct 15, 2006 | 02:46 AM
soros151's Avatar
Do I have to open the OBD2 plug?
Old Oct 15, 2006 | 02:49 AM
ProshopXB's Avatar
There are 2 clips on either side of the plug..that you can push in and it will slide out of the metal bracket that holds it.. then look for the black wire, tap into it by some means and you should be good to go..
Old Oct 15, 2006 | 02:50 AM
soros151's Avatar
Thanks.
Old Oct 15, 2006 | 02:52 AM
ProshopXB's Avatar
Thanks.
No prob..let me know if you have any more questions..
Old Oct 15, 2006 | 02:53 AM
soros151's Avatar
I will.
Old Dec 30, 2006 | 05:54 PM
Tboneterenzi's Avatar
hey proshop is this the same for the xb, i am in the middle or installing a shift light, and i am lookin for the wire. thanks.
Old Dec 30, 2006 | 08:50 PM
imsonofagun's Avatar
http://trdsparks.com/install/00602-83400-005inst.pdf
pages 20-28 for the xB. The xA and tC are also listed in there in the pages prior.
Old Dec 31, 2006 | 05:33 AM
thanks i didnt get the trd one, i got the proform one....
I finaly got it installed and it is soo nice. i just tryed all the different wires in the plug under the fues bot, and i found the one. now i can crank the music, and not have to forget to shift and over rev. But the light is sooo bright, i need to leave the cover on.
Old Dec 31, 2006 | 05:35 AM
soros151's Avatar
I got a similar one. Nice.
Old Dec 31, 2006 | 05:42 AM
I don't have the TRD shift light either, but the tach wire listed in the TRD installation guide is the same tach wire used to attach any shift light. Can be used to attach any aftermarket shift gauge too. I used that install guide for my shift light which made it a simple job, no guessing or anything.
Old Jan 2, 2007 | 03:44 AM
06SuperWhite_SoCal_tC's Avatar
Does anybody know where to tap in to make my boost gauge's light come on with my dash lights???
Old Jan 2, 2007 | 05:01 AM
soros151's Avatar
any 12V source
