Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Suspension & Handling
Register Forgot Password?
Reply
Old 10-30-2006, 11:10 PM   #1
Papispico
tC squad
Papispico's Avatar
Papispico 29/M
Send a message via AIM to Papispico
Default Tire Light w/ drop?
So i lowered the car on some Htechs about 2 weeks ago. And ever since then my tirepressure light would turn on periodically. Id reset it. and in about 4 hours it always turns back on. I know its not tirepressure. checked all and registered all at 45psi.
Any ideas why this light keeps turning on?
'Bronx Tc Squad Representa' #1
Papispico is offline   Reply With Quote
Old 10-30-2006, 11:24 PM   #2
MJVsTC
MJVsTC's Avatar
MJVsTC 24/M
45 PSI!? It should be around 32 PSI front and 28 PSI in the rear.
Matt
MJVsTC is offline   Reply With Quote
Old 10-30-2006, 11:24 PM   #3
sddykstr
sddykstr 25/M
Send a message via AIM to sddykstr
WOW! That is way too high, I agree with MJV.
'07 NBM tC, Injen CAI, 35% tint, Razo Shift Knob, OBX Pedals, Blue Cold Cathodes, LEDs, Figure Grilles, Tanabe Medallion Touring Exhaust
sddykstr is offline   Reply With Quote
Old 10-31-2006, 12:02 AM   #4
SquallLHeart
Super Moderator
SuperMod
SquallLHeart's Avatar
SquallLHeart 29/M
Send a message via AIM to SquallLHeart
.. 45?!?!?!?!
32/29 front/rear....
please??
the source of original LED ideas - swap expert - parts available Become a fan! LED-Headz
need 2nd GEN tC info? disassembly? questions? i got most of it down.
need help? call me: 408-905-7769
me like:
Doctor Isotope | PrecisionMuffler | 365motorwerks | LEDmod.com(custom Gaugefaces)
SquallLHeart is offline   Reply With Quote
Old 10-31-2006, 01:03 AM   #5
Papispico
tC squad
Papispico's Avatar
Papispico 29/M
well my tire said max of 51psi. and since i cant find out what the PSI is that will make the light turn on i just made sure it would be high enough that i know it wasnt the tire psi making that light turn on.
any ideas what it could be?
Old 10-31-2006, 01:09 AM   #6
atodak
atodak's Avatar
atodak 36/M
Send a message via AIM to atodak
check onthe drivers side door jam for the correct psi
"Fast guys know where they must go slow so that they may go fast in the fast parts. " - Jack Lanier
atodak is offline   Reply With Quote
Old 10-31-2006, 01:13 AM   #7
SquallLHeart
Super Moderator
SuperMod
SquallLHeart 29/M
it's your tire pressure being insanely high...
the specs are located right where the door jam is and it's also in the manual....
and i just told you... 32/29..... front/rear...
deflate to correct numbers... and then reset the light again.
please??
me like:
Old 10-31-2006, 03:37 AM   #8
Papispico
tC squad
Papispico's Avatar
Papispico 29/M
i was @ 33/30 and the light came on also. SO i set the PSI to a higher level. And its still comming on. I didnt want to post and have about 30 comments about my psi being too low. ive since then come back to a psi setting of 32/29 as stated by u guys...
read in another thread about having the car in acc mode and not started and to push the button let it clear. push the button again for like 3 second till it blinks and i should be ok. will try it out 2morrow.
Old 10-31-2006, 05:05 AM   #9
SquallLHeart
Super Moderator
SuperMod
SquallLHeart 29/M
yeah.. make sure and hold the button in... don't just press it and let go.
the tires should be even up front.. and even in the back..
i had a deal where the two tires up front were 32&32.. but my rears were 31&29.... deflected the 31 down to 29... reset... light didn't come back on afterwards..
how that 2 psi made a difference? blah.. how that happened? dunno..
please??
me like:
Old 10-31-2006, 02:00 PM   #10
Otocan
Otocan's Avatar
Otocan 113/M
Send a message via AIM to Otocan Send a message via MSN to Otocan
the tire pressure warning light isn't a "Low tire pressure warning light"
it's a "one or more of your tire's is different than the rest and you should figure out why" light
also, it's a "Wait a minute, WTF, these things were at like 28PSI before, and now they're all at 45PSI, get off your butt and figure out why" light
Set the fronts at 32-34, rears at 28-30, turn the key to the "on" position without starting the car, hold the button for TEN+ SECONDS (says so in the manual) and the light will turn off.
The sensors use the ABS system to calculate the deceleration rate of each wheel in comparison to eachother to determine if something is drastically different.
A sutdy at Cabmirgde Unvireisty shwos taht the hmuan brian deosn't raed ecah letetr of a wrod, but the wrod as a wohle. Olny the frist and lsat lteters hvae to be the smae. The rset can be a hgue mses and be raed wihtuot mcuh of a porlbem. Prtety werid,huh?
Too Many Options To List -See Profile
http://www.newgrounds.com/portal/view/206373
Otocan is offline   Reply With Quote
Old 10-31-2006, 02:10 PM   #11
Papispico
tC squad
Papispico's Avatar
Papispico 29/M
lol. Ok people. We can all stop the OMG 45 PSI ranting. its been back to 32/29 since about 8pm last night.
guess u didnt catch that?
none the less. light hasnt turned back on.
Old 10-31-2006, 08:35 PM   #12
SquallLHeart
Super Moderator
SuperMod
SquallLHeart 29/M
yea!! nice..
and just the fyi for people..
the '07's and above don't use the abs type system but actual wireless pressure sensors that sends feedback to the ecu... they will be need to be transferred to new rims if you get them.
blah blah... blah...
please??
me like:
Old 10-31-2006, 10:21 PM   #13
bkuhl
bkuhl 32/M
Send a message via AIM to bkuhl Send a message via MSN to bkuhl Send a message via Yahoo to bkuhl
yeah, and I believe the dealership charges like $30/rim to swap them over. unless you don't mind an annoying amber(unmodified...damn you LED Headz!!!) constantly on in your dash
1995 Nissan 240SX SE S14.5 RHD
TOMEI Powered Redtop SR20DET @ 18psi (447rwhp / 409lb/ft)
2011 Subaru Impreza WRX STi
Cobb Stage 2 @ 18.5psi (348awhp / 351lb/ft)
bkuhl is offline   Reply With Quote
Old 10-31-2006, 10:49 PM   #14
SquallLHeart
Super Moderator
SuperMod
SquallLHeart 29/M
$30 a rim?! screw that... i'll go do it myself.....
please??
me like:
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
