Rough clutch and gas Pedal
Old Nov 7, 2006 | 05:55 AM
silverevo05's Avatar
Default Rough clutch and gas Pedal
Anyone feel that the clutch pedal feels rough when changing gears or the gas pedal past 3500. My wife has an 06 xb, auto though but it feels much smoother at the same rpm
anyone else feel this or am I having some other probs?
Old Nov 7, 2006 | 09:20 PM
vintage42's Avatar
Default Re: Rough clutch and gas Pedal
Originally Posted by silverevo05
Anyone feel that the clutch pedal feels rough when changing gears or the gas pedal past 3500. ...
Are you saying the clutch pedal's action has a rough spot when upshifting over 3500 rpm? The rpm should not make a difference in how the pedal feels.
... When I step on the gas, It feels as though there is a pause, then a clunk... So I adjusted the free play on the clutch (put the screw right at the green tab (there was play before)...
I see a green plastic wear button on the pedal that contacts a switch on the floor. There is a nut to adjust the point where the switch engages - perhaps that is what you did. I don't see how the hydraulic clutch itself has any adjustment.
... am now wondering... How do yu adjust the free play on the throttle cable... Toyota says everting OK, car run good...
I would leave that to the dealer.
I hear a tick everytime I push on the brake pedal.... it happens when I barely tap on the brake (in the beggining), once i fully depress it, its gone... I use to get it on the clutch pedal but it seems to be gone...
You certainly are having a lot of trouble with the foot controls. Since you have been adjusting them yourself, I assume the car is out of warranty. Because if the car is under warranty, your efforts may have relieved the warranty of responsibility. You might not be qualified to do these adjustments. I would take a drive with the dealer's' mechanic and see if you both can come to some agreement on whether there are any problems and what needs to be done.
Old Nov 7, 2006 | 09:50 PM
yes vintage my car is an 06 and is completely out of warranty
I put 46345 miles on it
I am also adjusting everything on my car, throttle cable slack, brake pedal, temperature, radio stations, tire pessure everything
thanks for your help
Dapitt84
Mar 4, 2015 02:03 AM
greddy05tc
Feb 20, 2015 02:16 AM
blueonyxxB
Jan 21, 2004 05:52 AM
blumonde
Jan 19, 2004 11:47 PM
insane451
Dec 10, 2003 11:36 PM
