Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Wheel & Tire
Register Forgot Password?
Fitments, widths, brands...
Click Here
Reply
Old 11-09-2006, 09:18 PM   #1
TongMan
TongMan's Avatar
TongMan 29/M
Send a message via MSN to TongMan
Default Larger wheels and Odometer
Is this true?
Quote:
When you drive on the larger tires, your odometer reads lower than the actual distance travelled, so if it read, say 280 miles you might have really travelled 300. Then when you calculate mileage it comes out too low.
I have 19's on my tC right now. The odometer would still think I have 17's on from the manuafacturer. If my odo reads that I've only travelled 100, would that mean that I had already travelled 120 miles?
So, larger wheels wouldn't really equates to worst gas mileage, right?
2006 RS2.0 tC #0540 on May 3, 2006
TRD Supercharged on Aug 25, 2006
SOLD on Jan 5, 2008
TongMan is offline   Reply With Quote
Old 11-09-2006, 10:07 PM   #2
nodsetse
nodsetse's Avatar
nodsetse 52/M
Default Re: Larger wheels and Odometer
Quote:
Originally Posted by TongMan
Is this true?
It's not the wheels themselves that make such a statement true, but the overal diameter of the tire. If you upgrade to larger wheels, but also go with a tire that has a lower aspect ratio, it's often possible to maintain the same overall diameter as stock, such that your speedo and odo are both still accurate. As is, the statement would only be true if the overall diameter was increased.
As for gas mileage, the same as implied above is true. If the new wheel/tire combo has the same overall diameter and weight as stock, then your gas mileage should stay the same. However, if your overall diameter increases with the upgrade, then it's more likely you'll get better gas mileage (not worse), because you'll be turning lower RPMs for a given speed.
'06 Azure Pearl tC 5spd
nodsetse is offline   Reply With Quote
Old 11-10-2006, 01:57 AM   #3
TongMan
TongMan's Avatar
TongMan 29/M
So I'm getting better gas mileage by increasing my rim size? That is a good thing, if you ask me.
SOLD on Jan 5, 2008
Old 11-10-2006, 02:45 AM   #4
kenr74
kenr74 39/M
You MAY get better mpg depending on your driving. It will take more power to turn a larger tire so if you do lots of city driving you will most likely get worse milage. If you do a lot of highway driving then you could get better. The other issue with taller tires is that you normally end up with wider tires also which means more rubber on the road and less mpg.
kenr74 is offline   Reply With Quote
Old 11-10-2006, 03:04 AM   #5
SquallLHeart
Super Moderator
SuperMod
SquallLHeart's Avatar
SquallLHeart 29/M
Send a message via AIM to SquallLHeart
uhm.. most likely... no.
bigger rims usually weigh more.... but yeah.. depends alot...
there's alot of information out there... you just need to search for it.
please??
the source of original LED ideas - swap expert - parts available Become a fan! LED-Headz
need 2nd GEN tC info? disassembly? questions? i got most of it down.
need help? call me: 408-905-7769
me like:
Doctor Isotope | PrecisionMuffler | 365motorwerks | LEDmod.com(custom Gaugefaces)
SquallLHeart is offline   Reply With Quote
Old 11-10-2006, 11:04 PM   #6
TongMan
TongMan's Avatar
TongMan 29/M
I feel so slow when on the 19s than when I'm on my 17s.
SOLD on Jan 5, 2008
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
