need help on side mirror removal
Old Aug 2, 2004 | 06:56 PM
Sid_xBicious's Avatar
Default need help on side mirror removal
I already took off the 3 nuts holding it. but can't find the harness head/end. how do i take off the harness?
thank you so much,
sid
Old Aug 2, 2004 | 07:59 PM
TheScionicMan's Avatar
There should be a couple of screws underneath, and in the door. I'm not sure which ones you have already done.
Old Aug 2, 2004 | 08:03 PM
yes i also tried to take off the star screws but no luck, no harness head.
any body knows how to take off the door panels?
thanks,
sid
Old Aug 2, 2004 | 08:22 PM
nevermind, that freaken harness is inside the door panel. door panel has 2 screws and i pop screw out side. after taking that off, i began to pull the panel from the bottom first then lift up.
thanks,
sid
Old Aug 2, 2004 | 08:23 PM
That's an easy one. Theres a screw in the door handle and the pull handle and a faky screw tab thing near the front edge of the door panel. Remove those, grab the bottom of the door panel and pull outward. It has several plastic clips that hold it on. They slip into the brackets, not like the old ones that were glued on and would break off.
Pull the panel outward. Unhook the wiring and lift the panel over the locking rod.
Old Aug 2, 2004 | 08:25 PM
Damn, see you can take this things apart faster than WRITING about taking them apart. I love the Box...
Old Aug 2, 2004 | 08:43 PM
thanks, every help counts!!!
sid
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
mischadoll
Mar 9, 2015 05:48 AM
mischman
Jan 14, 2015 06:07 PM
Male_Nurse
13
Mar 10, 2008 02:51 AM
