Trailer hitch for the xB
Old Aug 3, 2004 | 01:11 AM
tattoo2u's Avatar
Default Trailer hitch for the xB
Does any know where to get a hitch for the xB? I know the book says towing is not recomended but they make a hitch for the Matrix and it says the same thing. I just want to tow a motorcycle not a yaht.
Thanks for any help. :?:
Old Aug 3, 2004 | 02:32 AM
Fr8mvr's Avatar
https://www.scionlife.com/forums/vie...=trailer+hitch
Old Aug 3, 2004 | 03:45 AM
LeetXB's Avatar
You folks are pretty good at staying between the lines for people who bought such a different car. 350Lbs for the bike and a trailer that will likely be less than 500Lbs does not mean you are going to fly off the road instantly. Towing a trailer can increase your braking distance by 100% or more easily. If you have never pulled a trailer I'd start off light, (pull lighter loads a bit to get a feel for it, you will have to modify your driving habits significantly) but I believe the echo is rated for 2000Lbs trailer weight. And before it comes up, GVWR is not the number to look too for towing capacity - but could give you an idea of a limit you'd certainly be safe at. Towing capacity is always significantly higher than GVWR. As far as the short wheel-base, I towed quite a few trailers with my Broncos and it was great: I never had any problems underway - and was fantastically maneuverable backing and forward. Actually, it would have been possible to damage the truck with the trailer by turning to sharply and I wonder if this might be one reason why they suggest against pulling a trailer.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Luna7ic
Sep 28, 2015 03:30 PM
interestingmoron
Sep 16, 2015 06:59 PM
jbernard
Sep 3, 2015 12:03 AM
