Exhaust Problem/Question help!!!
Old 12-11-2006, 02:03 AM
Cwatz5219's Avatar
Default Exhaust Problem/Question help!!!
I have a 2007 tc with a dual exhaust set up and yesteday i hand washed my car and when i got to the mufflers, my dumb a** thought that i should clean out the inside of the mufflers. So therefore i hosed down the inside of the mufflers thinking that i would be rinsing it out and that when i start up the car all the excess water would shoot out..... unfortunately that didn't work as i thought. Now my car when from sounding like a deep toned VWR32 to a very high pitched murano. Now my question is that i want to know from anyone else who may know or may have done what i have if my mufflers are now messed up or is it maybe because there still might be water in the canisters and if so will it go away eventually after it dries up?
Here is a clip of how my car sounded before i went dumb
http://www.youtube.com/watch?v=3gqMx2_5BVI
Cwatz5219 is offline
Old 12-11-2006, 03:06 AM
soros151's Avatar
Put it in a ramp as steep as u can, and rev it? Maybe this will work.
soros151 is offline
Old 12-11-2006, 03:12 AM
sddykstr's Avatar
Unless there is standing water in the pipes, I wouldn't worry about it. It will dry out...
sddykstr is offline
Old 12-11-2006, 03:29 AM
NightShade's Avatar
yuo could just remove the mufflers and let them sit with the tip on the ground. shake it out.
but looking from the vid, unless its cold out, maybe there is some water in it. and its being exaporated. unless its a large canister like a tsudo for exp. you might be worried it could have soaked the stuffings. the material that helps kepp the dBs down.
NightShade is offline
Old 12-11-2006, 04:36 AM
Cwatz5219's Avatar
unfortunately i can't remove the mufflers cause the whole set up is welded from the cat all the way back. I have 2 HKS turbo canisters. I'm worried that the water may have worked its way down to my cat. When i first start the car and drive for about 10 mins it gives off that high pitched murano sound but after half hour or so it goes away. I let my car run on a semi steep slope at work today for 3 hours thinking that it maybe it makes that sound for the first 10 mins because the car isn't fully warmed up yet, but it still gave that sound for a couple of mins after 3 hours running. Do you think the water may have rusted the insides of the mufflers and piping and thats whats causing that sound?
Old 12-11-2006, 11:58 AM
PghtC's Avatar
just out of curiosity, why wash the inside of your exhaust?
I don't know what could have happened there, it should just dry out on its own and nothing should have been damaged unless you used a pressure washer to shoot it in there.
PghtC is offline
Old 12-11-2006, 01:54 PM
NightShade's Avatar
Just hope you didnt spray for too long. some muffler manufactuers use FG as silencing material in mufflers, so that could have gotton soaked, if you sprayed long enough without seeing any water come out, there most likly is a little water in there, it should dry out, but it might sound slightly different.
Old 12-11-2006, 05:32 PM
Cwatz5219's Avatar
i used a regular hose with one of those straight shooting nozzels and honestly i spray in there for a while and i didn;t start the car until half hour later. I have no i dea why i thought u could rinse out the muffler, i guess i went dumb for min.
Old 12-11-2006, 05:36 PM
sciontctuner87's Avatar
start the car and let it run my buddy did the same thing the exhaust will get hot and it will turn to steam and it will be gone
sciontctuner87 is offline
Old 12-11-2006, 05:42 PM
Rob_Tampa's Avatar
If you could figure out a way to fit a smaller hose on a shopvac you could just suck it out.
Rob_Tampa is offline
Old 12-11-2006, 06:41 PM
projekkt's Avatar
Don't get too panicky now. Its water.
Fine tap water with a few elements that don't kill you.
But still water. Water goes away.
Water goes away even faster when its hot.
Exhaust gases are super hot.
I think thats enough.
projekkt is offline
Old 12-11-2006, 07:29 PM
chrischoi's Avatar
like he said. i would find a hill steep would work. pull the ebrake and start revving in neutral...
i dont think i would have washed out my
Originally Posted by Cwatz5219
HKS turbo canisters
by myself. where can i get some turbo canisters? those sound amazing. do they add alot of horsepower? I can't wait for 2 of them bload yotches. sounds like those things could do some damage and shoot mad fireballs. or little animals.
those things sound like they need professional rinsing out. just don't do it again. and let the experts do it. like chimney sweepers or something. they'll suck the water right out like santa. i think they charge like $50 an hour for labor to clean those bad boys.
but seriously. does sound pretty nice. did they just split it with a y connector?
chrischoi is offline
Old 12-11-2006, 11:44 PM
NightShade's Avatar
im curious to how its set up also. I'd like a set up like that. Any improvement over stock?
Old 12-12-2006, 12:31 AM
chrischoi's Avatar
i'd think not. just looks nice. someone at a muffler shop isn't gonna make you a exhaust system with any significant gains.
Old 12-12-2006, 12:33 AM
chrischoi's Avatar
but i think the turbo canisters would add like rocket propulsion hp numbers.
Old 12-12-2006, 06:04 AM
Cwatz5219's Avatar
To be honest i've read numerous threads about dual exhaust on a tc and how its only for show and theres no power gain and to me thats no true. As soon as i took it out the shop and drove down that street i felt an instant change in the way the car pulls. Unfortunately there isn't a dyno shop anywhere around me where i can get some proof but i used my cousins g-tech and it read 173 hp with 189 tq with the exhaust and CAI. Wether or not those numbers are true its still reading more than stock. Its different for a tc and i do turn a lot of heads with the sound because most people would never think its a scion coming down there street sounding like that and then they see the duals.
I have a custom 2.5 pipe from cat to axel and from there a 2.5 Y connector and then the 2 2.5 pipe to each muffler. I got these mufflers off ebay for about $40 a piece with shipping.
Old 12-12-2006, 06:08 AM
soros151's Avatar
I do not think it is 173hp. Much less 189tq. Try to find a dyno shop somewhere: Dyno Jet dealers in NY
NEW YORK
D R T Inc.
50-33 73rd Place
Woodside, 11377
Tel. 718-397-8586
Dyno Sport Performance
1011 Lakeville Road
New Hyde Park 11040
Tel. 516-775-1840
Lizzard Racing
20 Eads St.
West Babylon 11714
Tel. 631-420-1476
Kennedy's Dynotune
Model 224x
3165 Niagara Falls Blvd.
North Tonawanda 14120
Tel. 716-693-5354
Website: www.kennedysdynotune.com/
Mustang Magic
160 Brook Ave.
Deer Park 11729
Tel. 516-254-3430
Website: www.mustangmagicinc.com
New Era Performance
Model 224x
95 Mt Read Blvd Door #8
Rochester 14611
Tel. 888-865-1832
Website:www.neweraperformanceparts.com/
Email:sales@neweraperformanceparts.com
North Shore Auto Salon
325 Great Neck Road
Great Neck, 11021
Tel. 516-466-3368
P & J Speed Shop
195 Main St.
Tel. 716-694-6363
Website: www.pandjspeedshop.com
Pampena Motorsports
Model 424x 4WD Dyno
1743 Julia Goldbach Ave.
Ronkonkoma 11779
Tel: 631-738-0303
Website: www.pampenamotorsports.com
Power Surge Performance
15 Shagwong Dr.
Beach 11789
Tel: 631-821-3622
Ralph & John Auto
1323 65th St.
Brooklyn 11219
Tel: 718-837-3093
Website: www.RalphandJohnsAuto.com/
Email: rjautoshop@aol.com
Ray Z Engineering
115 Parker Ave.
Poughkeepsie 12601
Tel: 845-452-4527
Website: www.rayzengineering.com
Romar Enterprises, Inc.
P.O. Box 707
630 Rte 52
Walden 12586
Tel. 845-778-2737
Website: www.romarracing.com/
Speedworld Auto Accessories
Model 224x
598 Sunrise Highway
Baldwin 11510
Tel: 516-771-2525
Website: www.Speedworld.com
Email:jimmy454@optonline.net
Spina's Engine Shop
3270 Ridge Rd.
Ransomville 14131
Tel. 716-791-4640
T & R Racing
Model 224x Dyno
94-36 Merrick Blvd.
Queens 11432
Tel: 718-725-0179
Website: www.rx7s.com
The Speed Shop
Model 224
5705 East Taft Rd.
N. Syracuse 13212
Tel: 315-452-3278
Top Level Automotive
Model 224x
2316 Atlantic Ave.
Brooklyn 11233
Tel: 646-262-0482
Tri-State Autosport Inc.
Model 424x
94-158 Merrick Blvd.
Jamaica 11432
Tel: 718-291-3717
The Vette Doctors Inc.
26 Elm Place
Amityville, 11701
Tel. 631-841-0779
Website: www.thevettedoctors.com/
soros151 is offline
Neothin's Avatar
your power numbers are way off.....
and i dont see a catback giivng you much in the form of gains...
but hey, whatever works
Neothin is offline
Old 12-12-2006, 01:46 PM
NightShade's Avatar
I'd like to see the set up frm under the car if possible. Im interested in that. What is the db? Is it at least under 95?
Old 12-12-2006, 02:18 PM
chrischoi's Avatar
wow. HKS turbo canisters for only $40 + shipping. now they're fake. i'm upset. i'm gonna cry now...
and it could be possible. 173hp crank.
i turn heads. oh yeah... it's not the car... but my good looks and stunna shades. everyones like dayum... balla status.
Quick Reply: Exhaust Problem/Question help!!!
