Be very careful closing your hatch, EASY TO DENT
Old Aug 7, 2004 | 01:40 AM
HellNBack's Avatar
Default Be very careful closing your hatch, EASY TO DENT
Toyota decided to use some really thin metal for the rear hatch lid...
Nobody notified me of this when I bought the car, so I never knew you shouldn't touch the hatch lid when you are closing the hatch.
About a week after I bought the car, I gave it a coat of wax and when I pulled out of the garage in the sunlight I noticed an indentation in the hatch. Incredibly ____ed I wondered how could it have been possible there was a ding on the car only after a week and ontop of the hatch lid. You won't really notice it, unless you look for it and at an angle that light can reflect off of it. Since it was hard to notice, I thought it was already there when I bought the car so I went back to the dealership... they simply told me that it's typical for auto manufactures to use thin sheet metal so I probably caused it myself closing the hatch, so I am ____ out of luck.
It sucks, because I never put that much pressure on that area. When I first bought the car I would use the 2 handles to pull the lid down low enough to were you have to touch the lid and then push it down by the edge letting the weigh of the lid close itself. But I still ended up with a ding there
$40 later... a Paintless Ding repair guy made it disappear and look good as new within 10 minutes.
Old Aug 7, 2004 | 02:29 AM
scion_jC's Avatar
one thing i dont understand with the hatch is that ther are two handles inside to help close it but wut good will that do ? .. all u can do is bring it down n then from the outside shut it . its a step process
Old Aug 7, 2004 | 02:32 AM
bB2NER's Avatar
Music City Scions
Be Happy... The BOX only has one handle WAAAAAAA
Old Aug 7, 2004 | 02:38 AM
JasonH's Avatar
I pull a handle then use one finger under the license plate to close it the rest of the way.
Old Aug 7, 2004 | 02:53 AM
2JZ's Avatar
2JZ
what he said... use the handle to pull down, then just press on the license plate to close.
Old Aug 8, 2004 | 01:25 AM
WaterDragon's Avatar
This is a little unnerving.... I was thinking about adding an aftermarket spoiler to the tC. Will wind down force dent the rear hatch?????????????
Old Aug 8, 2004 | 02:03 AM
zoltiz's Avatar
N.G.S.O.
I just pull on the inside handles then get out of the way and the thing slams shut.
Old Aug 8, 2004 | 02:08 AM
hawkeye's Avatar
Most aftermarket wings are designed only for show, and should not produce much downforce. Its more than enough reason not to junk up your car with useless fiberglass.
Old Aug 8, 2004 | 02:21 AM
TCMaster's Avatar
Default Re: Be very careful closing your hatch, EASY TO DENT
Sounds like one hell of a lie to me. Don't be so gulible.
Old Aug 8, 2004 | 02:27 AM
SWF_05_tC's Avatar
If you take the car apart, and go in between all the welds in the open spots, the entire car is like that, it sounds hollow when you tap on a panel from the inside. just gotta be more careful.
mischadoll
Mar 9, 2015 05:48 AM
TheTripleC
Jan 4, 2015 06:46 PM
BlueBox
14
Jan 15, 2004 01:08 PM
rjsalvi
11
Dec 24, 2003 03:23 PM
yanges
21
Dec 16, 2003 10:25 PM
