Windshield and Stereo Cover questions
Old Dec 28, 2006 | 12:18 AM
pier723's Avatar
Default Windshield and Stereo Cover questions
I wanna see if someone else out there is experiencing the same problems.
1)A month ago while behind a SUV, a rock cracked my windshield. The crack is very small, smaller than a size of nickle. Ever since then, when temperature gets really cold, or rain there would be two spots of moist on the inner part of windshield right above the vent, but not always.
I checked the crack, it didn't crack through. So, at this point, I don't know whats causing the moist to leak in...
What do you guys think it could cause the problem?? I really doubt its the crack. But, any input is welcomed.
2)How do you get rid of the squeeky noise from the stereo cover?? Is there something I can use to tighten the door? Its hella annyoing!! Thanks a bunch!!
Old Dec 28, 2006 | 12:33 AM
tc-guy's Avatar
did u seal the crack in the windshield? if not i suggest u do that. if u don't that little crack will spread all the way across if it is cold and u turn on your heater. i'm guessing that u didn't get it seal after the rock chip and moisture is getting in between the two layers of the windshield when it rains or it is cold. as for the sweaking on the radio door, take it apart and put some lube on the plastic joints.
Old Dec 28, 2006 | 04:41 AM
pier723's Avatar
no.. i didn't seal the crack. i supposed i should do it soon, like now. Thanks for the tip! the moist isn't in between both layers of glass, but rather on the inside. Thanks again!
Old Dec 28, 2006 | 05:19 AM
SquallLHeart's Avatar
radio door squeak
https://www.scionlife.com/forums/viewtopic.php?t=87166
https://www.scionlife.com/forums/viewtopic.php?t=106005
Old Dec 28, 2006 | 02:18 PM
365Motorwerks's Avatar
My insurance covers filling the windshield chips..don't know about yours but it might not hurt (your wallet) to ask...
wiltonhall
Jun 23, 2025 10:09 PM
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
toyotaisme
Jan 10, 2015 10:24 PM
