Can you stretch springs?
Old Jan 16, 2007 | 11:40 PM
goyogi's Avatar
Default Can you stretch springs?
I'm not into lowering my cars. I like the ground clearance. Unfortunately all the springs for the xB are lowering springs. I'd like to get some progressive springs and was thinking, is it possible to stretch the springs to not have as big of a drop? How would you do it?
Old Jan 17, 2007 | 03:14 AM
kenr74's Avatar
Don't have a clue about the xb but lots of cheap truck lifts just use spacers under the springs.
Old Jan 17, 2007 | 03:22 AM
cherryBox's Avatar
stretching springs is not a good idea. it's on the same order as cutting and heating.
essentially what you'd end up with is unpredictable spring rates at all four corners, along with weakened springs. remember, it's the springs that carry the weight of the car, not the shocks.
if you're looking for 'not that big of a drop' check out the trd springs!
Old Jan 17, 2007 | 05:45 AM
goyogi's Avatar
thank you for the replies. I think I'll look into the spacers.
Old Jan 17, 2007 | 05:57 AM
06B0X's Avatar
If your willing to spend money - I bet a company such as Eibach would make you any spring you wanted.
Old Jan 17, 2007 | 06:41 AM
bB2NER's Avatar
Music City Scions
You could add adjustable spacers that do kinda stretch the springs apart between 2 of the coils for say maybe a half inch or so of lift. Or use spacers out back and maybe find a strut that is a bit longer between the spring mount and the lower mounting holes.
Old Jan 17, 2007 | 11:39 AM
DJ_SpaRky's Avatar
I'd say either get custom springs (Eibach or other) or go with Coilovers, most of them can provide up to a 1-1.5" lift.
Old Jan 17, 2007 | 02:48 PM
cherryBox's Avatar
NO. please do not even consider this.
The springs carry the car, and the shocks dampen the return rate of the springs (keeps it from bouncing). if we've been over it once, we've touched it 100 times - you won't be adjusting the ride height with shocks or struts. if you WERE to find a shock that holds the car up higher than the spring wants it to be (basically, this 'shock' would need to be completely compressed, and have virtually no suspension value whatsoever). your springs could potentially become unseated.
Old Jan 18, 2007 | 07:57 AM
bB2NER's Avatar
Music City Scions
You have no clue about what I meant. What you explained (except for the first part) makes no sense. :?
The strut would end up doing the opposite thing that the Echo Monroe replacements do. Get it now? If not oh well
Basically tho, if you can afford the coilovers that would be the best and most safe route to gain some added height.
Jayrdee
Oct 15, 2015 03:38 PM
domincnTC
Aug 4, 2015 01:47 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
