How to install tC side mirror assembly
Old 01-25-2007, 08:49 PM
lucas9000's Avatar
Default How to install tC side mirror assembly
I had to replace one of the side mirror assemblies on my 2005 tC, and searched the forums for how to do it. There are posts that say how to do it, but nothing too in depth. It's not that complicated, but I'll give a step-by-step of how I did it anyway.
On the inside of the door there is a triangular plastic cover opposite of where the mirror attached. Pull/pry that off (it's just clipped in). That will reveal the bolts and plug that connect the mirror.
Unscrew the bolts and unclip the plug. On the outside, there are two little clips that attach the assembly to the rubber seal on the edge of the door. Unclip those, then take off the old mirror assembly.
Now you basically put on the new mirror assembly by going in reverse order: attach the seal clips to the mirror, slide the bolts through the three holes and tighten them, and clip the power plug. Obviously you pop that triangular cover piece back when that's all done. That's it.
Again, very simple and certainly something you don't want to pay a dealer's labor rates for. It takes 5-10 minutes at most.
I'll also mention that I got mine from trdsparks.com for about $145. I recommend them.
Hope this helps,
Lucas
lucas9000 is offline
Old 01-25-2007, 10:16 PM
EddyXP's Avatar
145? are you serious? Please let me know how!
EddyXP is offline
Old 01-25-2007, 11:19 PM
Spect2K3's Avatar
Nice. Its real simple, but I wouldve been hesitant to do it had I not read this (not having known how it works). Thats for the writeup. And yea, trdsparks has good prices
Spect2K3 is offline
Old 01-27-2007, 06:52 PM
daewonder's Avatar
i just had a mishap and will have to replace my passenger side mirror. i'm glad it's easy to replace but i'm not glad it's gonna cost $145. damn.
daewonder is offline
Old 10-17-2010, 12:41 AM
jacksparrow's Avatar
Hey Lucas, or anyone else who successfully removed/installed their side mirror assembly:
Thanks for the step-by-step. Seems easy enough, but I pried the triangular piece off only to discover that I am unable to unscrew the bolts. I don't think I have the right tool; what tool/gauge did you use?
Thanks!
jacksparrow is offline
Old 10-19-2010, 09:59 PM
tCjosh's Avatar
3 year bump woohoo!!!
i think those bolts are 10mm size...
tCjosh is offline
Old 10-19-2010, 10:00 PM
SquallLHeart's Avatar
not bolts. they're nuts.
10mm nuts.
SquallLHeart is offline
Old 04-01-2013, 12:00 AM
Frankspin's Avatar
Default Lucas well done
Lucas your post was much appreciated. Very helpful and precise.
Frankspin is offline
xBSciontist
06-18-2019 03:06 PM
mischman
01-14-2015 06:07 PM
minter66
12-15-2014 01:45 PM
Male_Nurse
13
03-10-2008 02:51 AM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: How to install tC side mirror assembly
