The Legacy of Installing bBist LED tail lights
Old Feb 4, 2007 | 02:51 AM
SirPhobos1's Avatar
Default The Legacy of Installing bBist LED tail lights
So at around 7:30pm I pull the car into the garage, and my dad and I tear apart the back end so I can install my new tails. We get one side done, and decide to test it... below is what happened...
Attempt 1: running lights, no brakes.
Attempt 2: no running lights, no brakes.
Now, after the first attempt, i flipped the LED connector as instructed by the included instructions. This produced the second attempt results.
Okay, I think... I've blown a fuse somehow. So i learn which fuses go where, and pull them... to confirm, yes, i have blown the tail fuse. So i replace it... and discover through more attempts that i've also blown the stop fuse. the F word.
At this point, I go out in search of replacement fuses (this is before I realize i have a spare under the hood...)
Another attempt, another blown fuse later, I look at the wiring on the tail light and discover that they're not wired the same...
Tail light L
R---
G---
B---
B---
Tail Light R
R---
B---
G---
B---
So, I decide to install the Right side (Passenger) tail and see if it's wired correctly. And, it is.
To make a long story short, I had to rewire the driver's side tail light. What was a 1hr install turned into a 3 1/2 hour install with 5 blown fuses.
Time to email bBist and make them aware of it.
Lights look awesome now! pics tomorrow after i wash her!
Old Feb 4, 2007 | 03:04 AM
scionetics's Avatar
Old Feb 4, 2007 | 03:07 AM
Neothin's Avatar
he said they'd be up tommorow.
quality control = bleh apparently. that's not a mistake that should be made.
ah well, at least you found the culprit and fixed it!
Old Feb 4, 2007 | 05:32 AM
etsnet's Avatar
That sucks! That's like the Anzo taillights (I think) where you have to do some fix for it to work right. What kind of crap is that?
Also, what all did you have to do to get the taillights in and hooked up (assuming they worked right)? It shouldn't take but 15min. to install the tails. You don't have to pull the whole bumper off. I think it's like one of those plastic things and a screw on each side and unbolt and rebolt tails.
Old Feb 4, 2007 | 07:08 AM
Ryz0n's Avatar
The anzo's don't need any fixes, you gotta just plug them in both ways to see which way they're supposed to be.
What spare fuses are there under the hood? Does the car have like a little fuse removal tool somewhere? Gettin them out is a b****.
Old Feb 4, 2007 | 09:08 AM
JOEinSD's Avatar
There's a fuse removal tool under the fuse box lid... It's white..
Old Feb 4, 2007 | 12:06 PM
SirPhobos1's Avatar
Yeah, I didn't completely remove the bumper. I just pulled the clip at the bottom, the screw in the wheel well, and the screw at the hatch. the pain was detaching it from the clips. I felt like i was going to break something the entire time.
What took all the time was dealing with the blown fuses...
There are 3 spare fuses... 10A, 20A, 30A. They're in the lid of the engine compartment fusebox, along with the tool.
Old Feb 8, 2007 | 10:38 PM
SirPhobos1's Avatar
Well... the car isn't exactly clean, and it's -5 out, Here's the tails....
Old Feb 8, 2007 | 10:41 PM
davedavetC's Avatar
they look like the ebay tails....
Old Feb 8, 2007 | 11:31 PM
Jon's Avatar
Jon
Moderator
Moderator
^They are.
Old Feb 9, 2007 | 04:35 AM
SirPhobos1's Avatar
except I didn't get them from ebay... I got them from bBist...
Old Feb 9, 2007 | 02:41 PM
Jon's Avatar
Jon
Moderator
Moderator
But don't they cost more from bBist?
Old Feb 9, 2007 | 04:00 PM
XD40tC's Avatar
lol they look ok I suppose... too many different shapes in them though...
Old Feb 13, 2007 | 05:11 AM
CSOCSO's Avatar
since i know wich one is the turn signal on this tails.. i dont want them....
Old Feb 13, 2007 | 08:07 PM
1ahBSP's Avatar
i just threw up a little and swallowed it
Old Feb 13, 2007 | 08:28 PM
fox's Avatar
fox
LOL
Old Feb 13, 2007 | 08:37 PM
azepolyn's Avatar
maybe next time you see some icky tails you won't swallow
Old Feb 13, 2007 | 09:38 PM
SirPhobos1's Avatar
I didn't ask for opinions or smartass remarks.
Old Feb 13, 2007 | 11:14 PM
gjpjr84's Avatar
and this is Scionlife, where 95% of users thinks there own opinion is so important and the only correct course of action.
Old Feb 13, 2007 | 11:27 PM
1ahBSP's Avatar
this is a forum. you get smartass remarks. but i dont see anything smartass about mine. your taillights are ugly. doesnt go much further than that.
