Help Installing DC Strut bar
Well i have followed all the directions but i cannot get the inner nut off...I have the car jacked up and nothing...I cannot get that little nut off, if any one could share ideas it would be appreciated!
it a byotch to do, but take the top black cover off. first u need to take off the wiper blades. use a flathead and pop the cover on the wiper off the un-do the bolts for both wipers.
then use a phillips and poke the middle of all the tabs holding on the black cover. when u poke the middle of the tabs they should come out. after u take off the black cover u have access to all of the strut bolts so it won't be such a pain. u shouldn't have to jack up the car to install the strut bar. hope this helps
you do not have to remove the wiper cowl thing. just loosen(not take off completely) the last strut nut and the strut will move down enough to get the strut bar on. i had mine on in under 5 minutes. it's easy once you loosen that last nut. oh and you should and have to jack the front of the car up off the ground.
people say the strut bar does nothing unless you install it with the front tires off the ground. i get the idea of why but not sure how to explain it. but it's easy to jack the front end up so do it.
Originally Posted by salomon003
well i finally got it, it was a pain in the butt though...Thx for all the replys!
Thanks,
Brandon
Thanks,
Brandon
Glad you got it done. Can you explain how you did it??
Originally Posted by BrEaK_AwaY
Originally Posted by INFINI
Yeah mine made a big difference but I have an xA
and use the TRD strut.
and use the TRD strut.when i put mine on.. jacking the car up made installation a breeze.. was able to apply pressure on the tire, (which lowered the studs) so i had enough room to put both the strut tower and the nuts..
