Straight Pipe!!
Old Mar 4, 2007 | 08:54 AM
scion_mannnnn's Avatar
Default Straight Pipe!!
Anyone ever try this? I'm thinking it would be an easy DIY mod and it would gain some hp. also, would anyone know if it would pass emission?
If this ain't a good idea, what kind of aftermarket exhaust would be recommended?
_______
Old Mar 4, 2007 | 12:45 PM
streetlethalxb's Avatar
I've straight piped every car 've owned, except the box. I used a Tenrai axle back, its
quiet. But I dont see a problem with one, as long as your cat is still there. Noise
laws? Good luck!
Old Mar 4, 2007 | 06:06 PM
you notice any hp gained after adding the exhuast?
Old Mar 4, 2007 | 06:12 PM
jsa3mm's Avatar
If you cut off your catalytic converter you will not pass emissions. Also, if you do decide to take off your catalytic converter you will need an O2 Simulator to keep from throwing CELs.
______
Old Mar 4, 2007 | 08:37 PM
on my V8's it was a huge gain
Old Mar 4, 2007 | 08:45 PM
guitarguru44's Avatar
it will definitely be a gain.. its better than having a headerback exhaust i guess.. only problem would be the noise and you might lose some torque..
Old Mar 5, 2007 | 12:18 AM
wanachat15's Avatar
just a little louder. love the deep noise and no torqe lost. actually gained which is causing a lot of cluth slip and not beacuse my clutch is old.
ma thread: https://www.scionlife.com/forums/vie...595&highlight=
--tom
Old Mar 5, 2007 | 06:04 AM
how did you connect the pipping? any welding? bolt on?
Old Mar 5, 2007 | 06:53 AM
wanachat15's Avatar
for the test pipe where the cat was i just bolted it on. and for the piping i had to cut off the stock exhaust pipe (the flang side, inlet not outlet). so i welded that part to a 2 1/4" that i had a exhaust shop bend for me. i bought a stainless steel tip and tacked that on to the pipe. so it's the same as the bolt on axel back, but instead of an exhaust. it's a pipe with a tip. i wanted a jdm look so i had it at a up ward-right angle and sticking out about 3 inches from the bumper.
---tom
Old Mar 5, 2007 | 10:53 PM
wow, thanks for the details. ill be sure to post my exhaust when im done.
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
BlingSlade
Sep 5, 2015 08:52 AM
