Squeaking noise in the back of XA driving me NUTS!
Old Dec 12, 2003 | 03:00 PM
2002cbr600f4i's Avatar
Default Squeaking noise in the back of XA driving me NUTS!
Hey gang,
Have had my xA for nearly 2 weeks now. LOVE it. BUT, one thing is driving me crazy. Every time I go over a large bump (like say a speed bump, or a change in road surface) I get this really annoying squeak/ (plastic/glass) cracking type noise in the back. I haven't been able to figure out what's causing it yet. It's driving me nuts though. It's almost like there's a piece of plastic rubbing or tight or something like that.
Any suggestions? I guess I could take it to a Toyota dealership and have them mess with it...
--Mike
Old Dec 12, 2003 | 11:40 PM
magpie13's Avatar
I get that noise when I don't lock the backseat(s) in place.
Otherwise it's a quiet ride...
El Dingo
Old Dec 13, 2003 | 12:59 PM
dickpeter's Avatar
There is a TSB for rattles and sqeaking from toyota.
NV008-03
Old Dec 13, 2003 | 03:32 PM
fortyninerhater's Avatar
I get a noise coming from the back of my Xa also. I turns out that it's the tonneau cover. Pull it out ans squirt a little oil on the end that pushes in. It worked for me. Good luck.
-E
Old Dec 13, 2003 | 04:12 PM
DoNuT's Avatar
-E
It rattles for me, because when I go over a bump, the little flap bounces up and down. If you extended the cover out and locked it in place, I believe this could be fixed, although I haven't tried it myself yet =P
Old Dec 14, 2003 | 05:01 AM
I see. I had that problem in my Rav4. What I did to resolve that was tape on some velcro (the loop side) so that the tonneau rests on the fabric. It also tightens the fit. Give that a try. It may work in the Xa too.
-E
Old Oct 4, 2004 | 01:35 PM
Dylan's Avatar
-E
What is the tonneau cover? I get a similar noise from the back area of my xB and I'm not sure what it is. I've checked out nearly everything that people have suggested on the forum but haven't come across this "tonneau" cover issue. Please advise.
Thanks,
Old Oct 5, 2004 | 12:00 PM
Xcalibur1986's Avatar
I had this really bad, too. It turned out to be the spoiler. If you have one, go and see if it moves when you try to move it. If it does, and makes that noise you've been hearing, get the dealer to fix it. This really annoyed me, but it's only if you have a spoiler.
Old Oct 5, 2004 | 01:10 PM
Dylan's Avatar
No spoiler here. I've checked out other things like taping down the metal wires under the back seat's fabric. Also, I've taken off and put back the cargo cover and the noise still seams to be there. It's a slight squeaking/tapping/clicking noise. Really odd but also really annoying (when music isn't blarring of course).
Old Oct 5, 2004 | 03:14 PM
Dewmerz's Avatar
As crazy as it sounds look at the 3rd brakelight cover. On my xB I have had it break twice and am having the dealer put on the 3rd one today. The tab inside cracks allowing it to touch the glass lightly making noise. Mine even vibrates between 2800-3000 rpms.
Not sure how the brakelight cover looks on the xA...
Old Oct 5, 2004 | 04:09 PM
Dylan's Avatar
Thanks for the idea. I'll check it out.
I've noticed water condensation inside the brakelight covers. Since I never use a high-powered spray to wash my car, it's odd that water would get in there so easily just from daily use.
Dylan
Old Oct 11, 2004 | 11:21 PM
bB2NER's Avatar
Music City Scions
Have someone ride in back then drive the car over the same spot. they should be able to pinpoint the area of the noise then start pulling stuff off til it is found.
Old Oct 11, 2004 | 11:38 PM
TheScionicMan's Avatar
What about the license plate? Is it mounted nice and tight? Maybe dynamat it...
scotttie17522
Feb 23, 2020 08:38 AM
BManAmericae
Jan 18, 2015 12:17 PM
evolving_machine
Jan 13, 2015 08:04 PM
dcarter
Nov 17, 2003 02:02 AM
TheRedBox
Oct 8, 2003 04:25 PM
