1st post here *pix inside
Old Dec 14, 2003 | 01:37 AM
TinaXB's Avatar
Default 1st post here *pix inside
http://www.imagestation.com/album/?id=4288334155
these are the pix
I will try to upload them here but i dont know if it would work... the carbon fiber splitter is for sale.. i have a few sets brand new in box.. go to SALE SECTION for more info
Old Dec 14, 2003 | 01:49 AM
allblackxb's Avatar
NICE! Just a quick question, is the lip on the back wheels bigger than the front? I always wanted to see those wheels with the different offset.
Old Dec 14, 2003 | 02:05 AM
TinaXB's Avatar
Yes the rear lip is bigger than the front BUT since scion is FWD... it would be stupid to put different offset and width on the rear. but axis 7mod comes with MAXIS lips and they r the same offset and width with the front. so those lips r for looks ONLY and they are *FAKE* lips if u know what i mean.
Old Dec 14, 2003 | 02:32 AM
allblackxb's Avatar
Cool thanks for the info.
Old Dec 14, 2003 | 04:22 AM
bBted's Avatar
u car looks good man...i like those cf splitters
Old Dec 14, 2003 | 05:33 AM
its_ikon's Avatar
those splitters are nice. not overly done.
Old Dec 14, 2003 | 08:07 AM
HotBox's Avatar
nice xb how long have you had it? damn your other ride in a G35!!!!! LUCKY i wanted one of those but with everything i had wanted on it it woulda been over 40K so i waited and got my xB
Old Dec 14, 2003 | 02:20 PM
very nice! You might want to PM scionara he has been looking for those splitters for sometime now. But it looks good, I like it. I will have to check out the classified section myself.
Old Dec 18, 2003 | 02:09 AM
flipman's Avatar
What exactly is the "maxis" lip??? What offset are you on too?? It looks great.
Old Dec 18, 2003 | 02:14 AM
Besk_one's Avatar
i'm getting those same wheels in a week!
the "maxis" lip is an axis exclusive, it's where they have a different lip on the same offset and width wheel, thus looking like a staggered setup, but in reality it's not.
the wheels i'm getting are:
18x7.5" 35mm offset, but the front has a 2" lip and the rear has a 3" lip - same width, same offset, but fatter lip in the back for that staggered look
Old Dec 18, 2003 | 02:28 AM
scionracerxb's Avatar
HAHA...she's parked in front of jenny craig
Old Dec 18, 2003 | 02:53 AM
jjambox's Avatar
so when u have to rotate, will you just remove the tires and rotate those or will you rotate the 3inch lipped wheels to the front?
Old Dec 18, 2003 | 02:58 AM
Besk_one's Avatar
exactly, same as if you had a real staggered offset.
Old Dec 18, 2003 | 07:29 PM
Mr_scion's Avatar
N.G.S.O.
looks very nice what kind of hood is that?
Old Dec 19, 2003 | 08:19 AM
ScionVan's Avatar
Maxis lip and its "meaning" will be a misnomer because it isn't as simple as having a different lip for the same given wheel width and offset. Well, that is what you get, but unfortunately, Axis' marketing isn't educating the US public about the true meaning behind the wheel. The DISK is lower, meaning that the center mounting pad where you bolt the wheel to the hub is thinner. This moves the whole spoke section in while maintaining the same offset. The result is a deeper lip, BUT that also means that you now have less clearance for brake calipers. This isn't a problem in the rear of most cars that use single piston sliding calipers that don't have much clearance problems, or even on the Scions that have even more space because of their rear drums. But depending on the exact spec of the disk on the wheel (what is Axis' disk spec on the Maxis lip lineup?) and the width of your front brake caliper, you will probably not be able to just mount those rear wheels on the front.
12thhawksfan
Jul 14, 2015 06:18 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
umnitza
Dec 1, 2014 06:26 PM
