Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 03-27-2007, 05:29 PM   #1
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
Default my car is running rich
by adding a high flow cat will it kill the smell? if i drive with the windows down it smells pretty bad....
Sleep3r is offline   Reply With Quote
Old 03-27-2007, 07:15 PM   #2
biGhuK
biGhuK 113/M
Send a message via AIM to biGhuK
What did you do to make your car dump fuel in the first place? Adding a catalytic converter will help convert the hydrocarbons into carbon monoxide which will in turn, decrease the smell of gas, but this is only limited depending on how rich your car is running. If your car is running extremely rich you will essentially burn out the catalytic converter as well as spark plugs and the problems are endless.
"Knowledge speaks, but wisdom listens." - Jimi Hendrix
biGhuK is offline   Reply With Quote
Old 03-27-2007, 07:38 PM   #3
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
bump
Old 03-27-2007, 08:18 PM   #4
mahalzkita28
mahalzkita28 113/M
Send a message via AIM to mahalzkita28 Send a message via Yahoo to mahalzkita28
maybe you have an exhaust leak towards your header or spipe. becuase if you are driving with the windows down... and everything is bolted correctly, it would be comming out of the tip of your muffler and you wouldn tbe able to smell it. did you put back that little donut gasket between the header and the spipe?
-=TAKE2CREW=-
mahalzkita28 is offline   Reply With Quote
Old 03-27-2007, 08:27 PM   #5
toyota_scion_tc
toyota_scion_tc 32/M
Is your CEL on?
toyota_scion_tc is offline   Reply With Quote
Old 03-27-2007, 08:33 PM   #6
biGhuK
biGhuK 113/M
if you're running real rich you will see an excess of carbon build up on your rear bumper and exhaust tip in some cases. And like said before, check for exhaust leaks and of course if you're throwing a CEL then get the code pulled at autozone and come back here and post it.
Old 03-27-2007, 09:41 PM   #7
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
no cel, smell comes from exhaust
Old 03-27-2007, 09:46 PM   #8
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
i did the anti fouler trick, used the donut gasket between the header and s-pipe also
Old 03-28-2007, 04:13 PM   #9
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
sooo if i don't have a CEL i shouldn't worry right? thanks in advance
Old 03-28-2007, 04:54 PM   #10
biGhuK
biGhuK 113/M
yeah you should be fine, log your MPG and see what it's running.
Old 03-28-2007, 04:58 PM   #11
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
i got about 270 full tank freeway and city combined
Old 03-28-2007, 05:00 PM   #12
chrischoi
chrischoi's Avatar
chrischoi 26/M
Send a message via AIM to chrischoi
just start eating hot pocket lean pockets.
WFC #717
Sponsored and Supported by:
NurSpec | Tweaked ICE | RedlineGoods
chrischoi is offline   Reply With Quote
Old 03-28-2007, 05:12 PM   #13
biGhuK
biGhuK 113/M
Thats about 75 miles less than i'm getting per tank. I'm averaging 29.5 miles to the gallon with an HKS axle back and K&N CAI. That may be normal for the header application, anyone with experience on this wanna speak up?
Old 03-28-2007, 05:18 PM   #14
StealthScion
StealthScion's Avatar
StealthScion 32/M
its pretty tough to just guesstimate that you are running rich, especially if you are just NA w/ bolt ons, i highly doubt it.
StealthScion is offline   Reply With Quote
Old 03-28-2007, 05:26 PM   #15
BYeRhONe
BYeRhONe's Avatar
BYeRhONe 27/M
Quote:
and lean cuisine
- Byron
BYeRhONe is offline   Reply With Quote
Old 03-28-2007, 05:35 PM   #16
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
Quote:
you get 345?!?! i got 270 right when the gas light lit up so maybe i had a lot more...i usually don't drive it pass the light because of past experiences
Old 03-28-2007, 08:02 PM   #17
biGhuK
biGhuK 113/M
Yeah man, I average about 29.5 MPG.
Old 03-29-2007, 01:27 AM   #18
JDMonkiTC
JDMonkiTC 24/M
take ur car to a local tuner shop and see ur air fuel ratio
JDMonkiTC is offline   Reply With Quote
Old 03-29-2007, 01:34 AM   #19
Whocares05050
Whocares05050's Avatar
Whocares05050 26/M
Your not runnign rich with just bolt on's.
come on man, seriously. dont worry about it, you cars exhaust stinks because of the bolt on's. Have you never moded or been around a race track or any other moded car?
Dont mean to be an A$$, but you will be perfectly fine.
Whocares05050 is offline   Reply With Quote
Old 03-29-2007, 03:41 AM   #20
Sleep3r
Sleep3r's Avatar
Sleep3r 30/M
^^ no offense taken everyone on forums seem to be "mr. know it all's" j/k thanks man
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
