Air Management Valve Fill Controls
Old Apr 1, 2007 | 09:13 PM
SuperMario6582's Avatar
Default Air Management Valve Fill Controls
I started getting this clunking sound from the rear when I would lift it from full drop. I changed the shocks and am still getting the clunking sound. So I think that the rear is lifting up too fast for the shocks causing the sound. I found these and think they should do the trick. I was wondering if anybody has used these before?
http://www.suicidedoors.com/12PTCValveFillControls.php
http://www.suicidedoors.com/12ValveFillControl.php#
Old Apr 1, 2007 | 09:57 PM
damnbump's Avatar
you can do the same thing with ball valves from lowes,and they are like $5 a piece
Old Apr 1, 2007 | 10:16 PM
do you have those on yours?
Old Apr 2, 2007 | 12:58 AM
damnbump's Avatar
yes I have them plumbed inline with each bag so they serve as fill and dump controls.here is basically what I have.
Old Apr 2, 2007 | 01:16 AM
so you're just running four of them right? do you have any pictures of them installed?
Old Apr 2, 2007 | 03:06 AM
damnbump's Avatar
here are a couple pics,its not mounted yet.
Old Apr 3, 2007 | 07:24 AM
RTon20s's Avatar
Is it a clunk, or sort of a pop?
The reason I ask is that in some instances a double convoluted bag can sort of "seal" on it's self. When that seal frees up you will hear a clunk or pop.
Does the rate of lift change when you hear the sound?
Old Apr 3, 2007 | 07:31 AM
its more of a clunk. i noticed this weekend that after playing around with the bags, the less air you have in the tank the slower the up motion is. well as it started slowing, the rear would lift nice and easy without the clunk. this is why i figured that the rear is lifting to fast when the air tank is full or mostly full.
Old Apr 3, 2007 | 02:48 PM
surfcitylocal's Avatar
Dang it Mario, I told you to stop playing with your bags...you'll go blind!
Old Apr 6, 2007 | 08:00 PM
so i want to slow the air going up and down, would i need 8 of those ball valves, one for each valve?
Old Apr 6, 2007 | 08:12 PM
damnbump's Avatar
nope,if you run them inline with the bags then it will slow down up and down
Old Apr 6, 2007 | 08:43 PM
ok, sorry i'm not a whole lot sure when it comes to this, how many of them will i need then and how and where do i put them?
Old Apr 6, 2007 | 09:12 PM
damnbump's Avatar
you need four of them after all the valves right before the lines go to the bags
Old Apr 6, 2007 | 09:27 PM
ok cool, so basically it would go, valve, ball valve, air line, bag? my setup isnt like yours where the valves are connected right to the tank. mine are underneath the car, 4 in the front and 4 in the back. maybe i could post pics up of the valve setup and you could tell me where i would put the ball valves?
Old Apr 6, 2007 | 09:31 PM
damnbump's Avatar
you have it exactly right
Old Apr 6, 2007 | 09:41 PM
ok cool, i guess i'll start hitting up hardware stores to find me some ball valves. thanks man.
Old Apr 7, 2007 | 12:14 AM
low_down_xb's Avatar
why run big air line then put valves into slow you down, shouldnt you have just went with 1/4 line and spent less money for all your fittings, line, valves...etc, personally i like it fast...hehehe
Old Apr 7, 2007 | 12:30 AM
yeah, i like it fast too, but i think it may be too fast. at least when i put the ball valves on i can control how fast i want it. i want to just slow it down enough to where i dont get that clunking sound.
Old Apr 7, 2007 | 12:47 AM
did the noise change at all when you put the new shocks on?
Old Apr 7, 2007 | 12:50 AM
no still there
