Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 04-05-2007, 09:18 PM   #1
mcd
mcd's Avatar
mcd 26/M
Send a message via AIM to mcd Send a message via MSN to mcd Send a message via Yahoo to mcd
Default grinding gears
am i the only one who seems to grind gears way too often? i probably grind gears once every other day. i was driving a 1999 toyota corolla 5spd prior to owning the tc and i never had this problem. is it common with new cars? is it the tc's clutch? or do i suck at driving? jk :p
thanks in advance
ps. it doesn't seem to be the same gear every time either. sometimes 1-2. sometimes 2-3. and sometimes 3-4.
if i had a billion dollars.... yeahhhhhhh
mcd is offline   Reply With Quote
Old 04-05-2007, 10:07 PM   #2
nodsetse
nodsetse's Avatar
nodsetse 52/M
I've been driving anything and everything for >30yrs and initially had the same issue with my tC. All I had to do was slow down my shifting a bit, be very deliberate with the clutch, and now I almost never grind.
I know the clutch always engages at the same point during the pedal's range of travel, but sometimes I could almost swear it varies. It feels as if you have to push the pedal all the way in before it disengages, then let it almost all the way out before it engages again, which makes no sense.
'06 Azure Pearl tC 5spd
nodsetse is offline   Reply With Quote
Old 04-05-2007, 10:30 PM   #3
draxcaliber
Moderator
Moderator
draxcaliber's Avatar
draxcaliber 27/M
Send a message via AIM to draxcaliber
yeah, your just not holding the clutch long enough, your probably just not insync with the coordination between the pedal and shifter movement.
Takumi is a Japanese character that symbolizes a broader dimension than quality, a deeper process than education, and a more perfect method than persistence.
draxcaliber is offline   Reply With Quote
Old 04-05-2007, 10:42 PM   #4
ef91hatch
ef91hatch's Avatar
ef91hatch 28/M
ill be the first to admit.. the tc is hard to drive. i learned on porsche and that thing was a beast to drive but the tc is still difficult to shift and clutch
ef91hatch is offline   Reply With Quote
Old 04-05-2007, 11:24 PM   #5
Tcguy85
Tcguy85 28/M
Send a message via AIM to Tcguy85
i had problems when everything was stock. i added the engine damper, nst steel shifter cable bushings, then the creative compacts short shifter with base bushings, changed the fluid to reline MT90 and also i made my own clutch pedal stop to get rid of the excess clutch pedal travel.
after doing all those the shifting is awesome. i used to miss gears and grind them all the time but it got better with every one of those mods i did. with all of those mods it feels TOTALLY different now.
Jason B. - 07 FM Scion tC
Tcguy85 is offline   Reply With Quote
Old 04-06-2007, 12:34 AM   #6
707tC
707tC 25/M
Send a message via AIM to 707tC
a lot of the time im driving kinda hard i grind second or miss it. it takes a little more time to go into second than the other gears it seems to me
707tC is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
07, corolla, gear, gears, grinding, life, scion, tc, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
