Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Wheel & Tire
Register Forgot Password?
Wheels and tire combinations...
Click Here
Reply
Old 12-16-2003, 05:17 PM   #1
Besk_one
Besk_one's Avatar
Besk_one
Send a message via AIM to Besk_one
Default how about 18x7.5" 35mm offset, with 5mm spacers in back
i'm picking up some Axis Mod7 18x7.5" wheels with a 35mm offset, and was thinking about running a 5mm spacer in the back to bring the rear wheels more flush with the fronts.
i'll probably be running 215/35's, unless i decide on 215/40's (but probably not to keep the speedo kind of in check.
whatdda think?
Besk_one is offline   Reply With Quote
Old 12-16-2003, 06:33 PM   #2
randode
Wagonistas
randode's Avatar
randode 37/M
sounds good, but you may need longer studs.
www.randode.com
Air Suspension | Lighting & LED Swaps | Metal Fab | CNC Plasma Cutting
Air Stunner Elite struts by Randode now available
*100% fabricated strut housings *KYB GR2 inserts *UA Aero Sport bags *spherical top pivots *camber adjustment *made in the USA *available for xA/xB, Gen2 xB
randode is offline   Reply With Quote
Old 12-16-2003, 07:17 PM   #3
Besk_one
Besk_one's Avatar
Besk_one
Rodger (Scionara) has been running a 5mm spacer on his box for almost 10,000 miles, and says there are plenty of threds to hold the wheel - any longer and i'm sure i'd need the spacers with the longer studs, but 5mm should be ok i think, he hasn't had any problems...
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
18x75, 18x7535mm, 35mm, 5mm, iq, offset, scion, spacer, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
