E-Manage Blue / Ultimate Anti-Stall Programming
For those whom use these forms of engine management and have reported a stall when letting off of the throttle or putting the car in neutral and coasting; I will show you how to program your anti-stall setting to work flawlessly on your E-manage or Ultimate.
For E-manage Blue owners:
Support tool is needed to perform this!!!
For E-manage Ultimate owners:
- Connect support tool to E-manage
- Click Settings>Parameter Settings
- Check the box next to Anti-Engine Stall then click Confirm
- Click on the "ES" or Anti Engine Stall from the drop Down Menu at the top tool bar.
- Click Real Time Data Display
- Start the car and let idle
- Take note of the "Airflow Meter Output" voltage.
- Take that voltage output and add a small buffer of 5% to it.
- Take that voltage and input it into the "Clamp" row in the Anti Engine Stall Setting box across all RPM break points
- Change the TP% in the Anti Engine Stall window to 3%.
- Change time to 3 seconds or 5 seconds and you are done!
- Click on the little car on top tool bar
- Go to the "Map Select" tab and check the box for Anti Engine Stall, click apply then ok.
- Double click on Anti Engine Stall Setting on the left tree
- Hold "ctrl" on your keyboard and "t"
Paul... This is a prime example of why I love you. I've never bought anything from guys but next part I need I'm deff getting through you
Possibility of getting a DIY on basic tuning for emanage or even 2 step launch?
Tuning is a lot more complex and harder to denote through words. Plus there are many different tuning beliefs and schools of thought. Each person may tune the same differently.
